Results 1 to 8 of 8
Thread: wheel spacers
    atc110 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2002
    Milwaukee, WI
    244
    wheel spacers
    I just looked on durablue's site and it looks like they don't make wheel spacers for a ytm175. I was wondering if spacers for another bike would fit?
    thanks
    1982 Honda ATC 250R (for sale $600)
    1985 Honda ATC200X parts (for sale)
    1985 Honda ATC 110
    Quickonstep is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    Baltimore, MD
    368
    mesure across the hub, in mm's and then how many studs there are, and go from there if you have 4 studs and its 100 mm across, then you got a 4/100
    btw, when you mesure across, you have to go from the center of the stud, like an imaginary circle going around the centers of the studs, thats what you would mesure.
    Jesse
    conig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    tallahassee FL
    392
    as far as I know all hondas use a 4/110 pattern. I used 250r spacers on my 250ees big red.
    1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
    1985 honda es 250 big red.
    85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
    A trike to show up the modern utilitys
    2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
    Jun 2004
    Brazil, Indiana
    1,389
    no conig..not all do...my 185 has stock rims and hubs are 4/130 ..look at a denniskirk catalog..theres more stuff than the site for quads and trikes..mine match up with a suzuki 4 wheeler not sure what size tho
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
    Feb 2003
    Delano, CA
    616
    The YT175 has 3 bolt hubs, unless they've been changed.
    If you're not plaining on jumping it. Somebody on ebay sells stud extenders in 3.5 and 5 inch width.
    1979 Honda 110 ATC, CEET gas tank cover, 25X11X9 rear tires
    1984 Honda 110 ATC, orignal blue plastics,
    1982 Yamaha 175 TRI-MOTO, 26MM Mikuni
    Honda US90 ATC, Collecting Dust
    2004 TRX450R
    Aug 2004
    tallahassee FL
    392
    83 185 I tried to post exactly what you typed a minute after making my post because my 70 is not 4/110 but the site administrator gave me the, you can only post one message every 30 seconds message.
    Nov 2002
    Milwaukee, WI
    244
    should i just enter stud extenders in the ebay search?
    1985 Honda ATC 110
    Feb 2003
    Delano, CA
    616
    Here they're are. >LINK<
    Thats whats I'm plaining on doing to my YT175 when I get it running again. The only thing is, I don't if the studs are the same on a YT. So you'll need to look into that first to make sure that they'll work.
    But I've also heard that a banshee hub might work to on a YT since it works on a Z.
    2004 TRX450R
