Torque specs for handle bars
Does anyone have the torque specs for the handlebar hold down clamps on a 85 350x?. I am buying a book but i havent recieved it yet i just bought a set of Moose bars and want to get things right
Thanks
Happy Trails
I DON'T THINK I HAVE EVER SEEN A TORQUE SPEC ON BARS,,,, there is a mark or a dot on the clamps that goes to the top , if you look at them close you will see that they are cut different angles too,,, the one with the mark is supose to be bottomed out on the triple clamp then tension the bars with the other side,,, i always run mine a little loose so when i crash or hit something they will move, that way it won't bend the bars.
Thanks i will look for the mark when i install the bars. I always try not to wreck that usually puts me out of work for awhile
Happy Trails
//ArrowChat Integreation Code
