Results 1 to 7 of 7
Thread: Why???????
    Why???????
    Why would u have an open forum if u cant put anythin in there ? Ive put the same thing in there 2 days in a row and someone delete's it??? why dont u move it instead???
    Jul 2004
    Alberta
    0
    What did you put?
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by littlemax
    I sent you a PM about why it was removed. And I show you have read it.
    Did yoiu read the rules? NO Classified Postings outside of the classified forum.
    Yes, I personally removed both postings, and will do so again if needed. Things flow so much smoother if people follow the rules. Geesh!!!!!!
    Howdy
    yeah .... why didnt u move it instead?????
    May 2002
    Dublin, Georgia
    635
    You as the user are responsible for posting in the right forum. The mods are not here to put everyone's post in the right forum, they are here to make sure the posts stay within the rules for the forums.
    84 ATC200X--Wife rode it once, now I can't get it back.
    84 ATC250R--Trying to find piston for 300R kit.
    85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
    84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
    Howdy's Avatar
    Celina, Ohio
    10,079
    The question should be: Why didn't you post it in the proper forum in the first place? Had you posting it correctly then you wouldn't have gotten all ticked off at me for doing "My Job".
    But I will answer your question: It's easier to remove it, than to move it. So, why should I ( or any other moderator ) have to work harder to correct your mis-doings? We shouldn't have to. Think about it: Do you make your parents clean up your room?
    Howdy
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by ejc042
    Exactly!!
    You would think that someone that has been on the forums since Jan 2003 would know this by now.
    Howdy
