Results 1 to 15 of 19
Thread: don't laugh!!! how do you use an auto clutch?
    mikey's250sx's Avatar
    mikey's250sx is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    lancaster, pa
    417
    i've had dirtbikes and a few streetbikes and am picking up a 250sx on friday. i've found out they have an auto clutch. how's that work? do you just match engine rpm's and shift? do you have to shift into neutral to stop? i feel kinda silly asking but i have never seen or ridden with this set-up.
    thanks
    Nov 2004
    lancaster, pa
    417
    here's a pic
    Nov 2004
    Waterloo IL
    2,701
    It's centrifugal. You just shift like a dirtbike but you don't have clutch lever to pull. If you want to stop you let off the gas and it disengages you can let off in 5th gear and you will coast to a stop but then you'll want to shift back down to 1st to take off. Make sense. You'll get the hang of it immediately, nothing to it.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Nov 2004
    lancaster, pa
    417
    cool thanks. if i'm winding it out in 2nd and i shift into 3rd will the rpm's stay up or will they drop significantly?
    Ontario, CANADA
    4,538
    Start in Neutral, then push down on the left pedal with your foot. Now your in first and give her gas to go, when going to other gears let off gas and repeat with the left pedal. When slowing down let off gas the put your foot under the pedal and go up. Pushing down goes up(1,2,3,4,5) putting your foot under goes (5,4,3,2,1)
    there ya go, what year is the SX? have fun with it, mind if I ask how much your buying it for?
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Nov 2004
    lancaster, pa
    417
    it's an 85
    i'm paying 150 and an old laptop i don't use anymore.
    Jul 2004
    Mud hill. close to water !
    3,658
    By the way.
    the SX.. since i have one... great bike btw !!
    From neutral you shift up for 1st, 2nd .. ... and down to slow down, like the new quads adn what not.
    my big red is the oposite and it's weird going from one to the other.
    Autoclutch .. real simple.. to take off stay off the gas, just hit the shifter then hit the gas.. don't gas it when you shift or you will wheelie ( not that it's a bad thing !! ) and rev it up.. let go of gas, shift, rev... simple as can be !
    almac16 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2004
    Halifax, Nova Scotia, Canada
    226
    Also note that Reverse is 1 DOWN from Neutral and depending on the bike you may or may not have to hit the little button on the left side brake lever and pull the brake before it will shift into reverse.
    Double check that because some bikes are geared so you no longer have to pull the brake lever to go into reverse and you could accidentally go into it when shifting down
    Hampton, Virginia, C.S.A.
    2,664
    Quote Originally Posted by Kintore
    depending on the bike it might be.... up for 1,2,3,4,5 and then down for5,4,3,2,1
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Opelousas, Louisiana
    1,337
    pretty sure the 85 Sx is up 1,2,3,4,5 (down reverse)
    1986 350X K&N filter, DG Krome Power exhaust
    1982 110 UNI filter, Cobra megaphone exhaust
    1982 honda 110 exhaust for sale, PM me.
    Jul 2004
    Alberta
    0
    Quote Originally Posted by BIGCRIP28
    I have never seen a machine where you could directly shift into reverse(other then a vehicle..obviously)...
    All of the machines required you to pull a lever, or turn a knob thing(like the 200es).
    2,664
    Quote Originally Posted by TTribaLL
    yes but you press down after you pull the knob or pull the lever
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    azhondagrl's Avatar
    azhondagrl is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2004
    Lebanon, Oregon
    215
    I just recently got rid of my 85 sx, the gears are down for reverse, had to push in the little button the leftside of handlebar. then up was Superlow, then 1st, 2nd, 3rd and 4th, or 1,2,3,4,5 as most people call it. hope this helps.
    Jan 2004
    226
    It is very easy to bypass the "little button". All that does is ground the reverse switch that comes out of the bottom of your motor on the right side. Sooo.... take that wire and ground it yourself and your "little button" is permanately engaged. I've seen lots of people do this (including myself) when the trike has no brakes and sometimes not even a brake lever!
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    I must disagree about grounding the wire. The wire is for the reverse light. The button on the rear brake hand lever pulls a cable that allows the tranny to shift into reverse. the concept is that you have to pull the rear brake to pull the reverse cable, so the trike will be stopped. Shifting the tranny into reverse while the trike is moving is not something that you will do very many times without splattering the tranny.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
