Results 1 to 7 of 7
Thread: YTM225 bottom end noise
    I started up my YTM225 today and noticed a clunk sound in the bottom end. It sounds like it's coming from the right side of the engine (when seated on the trike) and the sound is relative to the engine speed. Any ideas? It also seemed like the thing didn't have as much pep as it used to, not sure if that is a related issue or not. Any ideas on what it could be? Thanks guys
    My Rides:
    JUST BOUGHT 1984 250R
    1984 YTM225DXL owned since Feb. 2004 , 88 TRX300 4x4, 84 YT125 , 90 LTF250 , and 86 KLF300
    Also various other non running things takin up space
    Dads is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2002
    Richmond, NH
    219
    does it seam to clunk clunk? like a rod bearing will do at top dead and bottom dead.
    or clunk pos clunk
    I would say clunk clunk. What would it be if it was a clunk pos clunk?
    My Rides:
    Quickonstep is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    Baltimore, MD
    368
    i would say its a rod bearing and thats what your getting... time for a rebuilllllllld!
    Jesse
    Dec 2002
    Richmond, NH
    219
    No telling what a clunk pos clunk would be. but it would not be the crank shaft.
    cranks go clunk clunk, rist pins go tick tick, valves clack clack clack.
    Chipped gear teeth can sound like a clunk pos clunk.
    Rod bearing sounds like it might be it, how hard are those to do? I've never really gotten into a 4 stroke. Thanks
    My Rides:
    Nov 2004
    Baltimore, MD
    368
    its not that hard, just gotta watch when you pull the head, the push rods are gonna fall.. just keep them in the same holes... mark everything, keep bolts you take outta the head together... etcetc... LABEL EVERYTHING! invest in some good baggies..
    Youll need a rod bearing kit, and while your in there you might as well do it right and rebuild the whole thing... id just get a new piston, new gasket kit, bearings, seals... if you need any help, dont be afraid to ask.
    Jesse
