Here is a link to some tires:
http://www.tiresnstuff.com/chen-c826.html
Would these fit on stock ytm175 rims (8")? Would these be good to put studs in? If so, what's the best way to go about this?
thank you
thank you
1982 Honda ATC 250R (for sale $600)
1985 Honda ATC200X parts (for sale)
1985 Honda ATC 110
I think they would work, the knobes look thick enough for studs
85 ATC350X- weisco 10.25:1, uni, +3 swingarm, 3in. wheelspacers, RAD carrier, 450r muffler
85 Big Red
83 KLT200
82 ATC200
If it aint broke fix it anyway because it soon will be
Thats the tire the pros use. I use them on a 8x8 rim. For best results angle your studs like in the pic. Think of a studded tire as you would a paddle tire, now run them the opposite way you would a paddle tire, this will give you the best traction. If you want to get really technical, line all the studs up in the same direction, also know as tuning your tires.
Are those just normal sheet metal screws you used on those? How long are they?
thanks
1985 Honda ATC 110
No, they are kold kutters, ice racing screws, 5/8" long, you can find them on ebay or your local atv dealer. If you try using sheet metal screws you will be left in the "ice shavings"Originally Posted by atc110
