Results 1 to 15 of 22
Thread: 250r forks
    Nov 2004
    Essex UK
    6
    250r forks
    Hi guys , I recently replaced the fork seals on my 250r and drained and replaced the fork oil but when I tried to pressurise them to about 7psi it read on the low pressure tyre guage but when I rechecked them it read 0.It seems as though they are losing pressure, or is it cos they only have a little air capacity that when rechecking I release the pressure? Also what keeps the air pressure in? is it the fork seals?
    Mar 2004
    Eastvale, CA
    630
    Yes & yes.
    Nov 2004
    Essex UK
    6
    So whats the best way to check the pressure?
    Mar 2004
    Eastvale, CA
    630
    I've seen kits that allow you to add air equally at the same time via two hose attachments. I don't know for sure, but it may have a built in gauge on it as well. You can always run 0 air and use a heavier oil for the about the same result.
    Nov 2004
    Essex UK
    6
    Was thinking that but just wanted cofirmation that it would work.
    Cheers
    Dec 2003
    Utah
    55
    You're not supposed to put air in the forks, it will blow the seals. The air valve is for bleeding the air. You're suspension builds pressure as you ride. If you want a stiffer ride, try a little more oil or a heavier oil.
    Mar 2004
    Eastvale, CA
    630
    WRONG!!! The following is taken right off a 1985 250R brochure
    Suspension, Front: 39mm air adjustable forks, 9.8-inch travel
    Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
    Wife's Ride - 2009 Polaris RZR 800
    Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
    Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
    got sand?
    Dec 2003
    Utah
    55
    That is pretty cool then. Every thing I have ever read about forks leads you to believe what I said earlier.
    Mar 2004
    Eastvale, CA
    630
    You can and will blow the seals if you over pressurize them or over fill them with oil.
    got sand?
    atczack's Avatar
    atczack is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    Fort White, Fl.
    423
    J La,
    Man I have alway's heard the same thing you said, the valve on top of the forks are for releasing built up psi. But then again, I've never read one way or the other in writing.
    1985 Honda ATC 250 Big Red
    "Ugly Betty" from the handlebars back it's a
    1982 Honda ATC200es, from the handlebars
    forward it's a 1988 Honda TRX 300 Fourtrax.
    "If you wanna play, you gotta pay..."
    Jun 2003
    englishtown NJ
    2,676
    I put 2 pounds in my 250r forks and at the end of the day, one had blown fork seals, so, I'll do that again
    Oswego, IL
    1,858
    that air thing it to let air out only. not to let air in. it says it in my manual!
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    Mar 2004
    Eastvale, CA
    630
    Ok boys & girls, everyone take out their 1985 Honda ATC 250R Owners Manuals and turn to page 20. Mr. Vartiak15, will you please read from the top of the page.
    "uhh, derrr, that air thing it to let air out only. not to let air in. it says it in my manual!
    (laughter)
    Settle down boys & girls. I think you have the wrong manual Mr. Vartiak15. I expect you to be better prepared next time. Here, let me read.
    Front Suspension
    The front suspension system uses air assisted front forks. The forks may be adjusted for the riders weight and riding conditions by adjusting the air pressure.
    Air Pressure Adjustment
    Low air pressure settings provide a soft ride and are for light loads and smooth riding conditions. High air pressure settings provide a firm ride and are for heavy loads and rough riding conditons.
    Note* Use of more than 10 psi is not recommended because fork action becomes very stiff and oil seal damage may occur.
    got sand?
    May 2002
    Southeastern Wisconsin
    3,658
    Every set of forks I've had I've set to 0. Block it off the ground so the front isn't touching, let the air balance to 0 using the air valves and presto, you have what I call the perfect set-up. IMO, you should use oil and different spring weights to change handling, not air. I don't really agree with Honda on that one.
    Clarks Summit PA
    1,236
    i agree.. no air pressure, just use different oil weights to vary your forks..
    Ride it like you stole it! And never look back! They are too far behind to see!
