Does anyone know anything about the big bore kit for an air cooled R? Can you still buy pistons for them? The cylinder is a factory Honda part, correct?
08 Outlaw 525s
07 CRF70
04 Harley FLHRCI
04 TRX90
03 XR650R
03 400EX- XR650R engine
02 XR100R
01 Banshee
00 XR50R
00 XR70R
99 PW50
99 JR50
96,95 Sportsman 400
95 Xplorer 400
94 Indy XLT
87 Trail Boss
86,86,86,86,86 Scrambler
86 TRX70 x2
85 ATC350X
85,84 ATC250R
85 Red Tecate
85 LT50 x2
84 XR500R
84,84,84,84,83,82,80,79 ATC70
82,79 XL500R
83 ALT50
79,78,77,77,76 XT/TT500
76,75,74 XL70
72,71,71,71 SL70
72 Harley FX
72,71,70,70,70,70,70 CT70H
72 SL100
70,69 Z50
Yes, the 300 kit is a factory Honda option. No the pistons are no longer available. I am still trying to find one for the 300 kit I have.
84 ATC200X--Wife rode it once, now I can't get it back.
84 ATC250R--Trying to find piston for 300R kit.![]()
85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
Let me know if you find a piston, I think I'm gonna buy the kit and start looking for a piston my self. I've heard of YZ250 pistons in a 250R so I bet just about any 2-stroke piston with the same bore can be made to work. Do you know how many milimeters the piston would be? How many times can you over bore it?
08 Outlaw 525s
07 CRF70
04 Harley FLHRCI
04 TRX90
03 XR650R
02 XR100R
01 Banshee
00 XR50R
00 XR70R
99 PW50
99 JR50
96,95 Sportsman 400
95 Xplorer 400
94 Indy XLT
87 Trail Boss
86 TRX70 x2
85 ATC350X
85,84 ATC250R
85 Red Tecate
85 LT50 x2
84 XR500R
82,79 XL500R
83 ALT50
76,75,74 XL70
72,71,71,71 SL70
72 Harley FX
72 SL100
70,69 Z50
76.00mm is stock and it can go out to 80.00mm
Good luck with finding a piston.
Hmmm... if you have the "kit" it should be included. I've got a 300R head here. Saw a guy have a huge motor lot in Cali a month or so ago that had a 300R jug with it. He wouldn't seperate it and I wasn't going to buy 6 motors to get the 300R jug.
Bruce
'86 ATC350X - 'Go-Go Girl'
'85 ATC70 - All Original
'83 Suzuki ALT125 - Pieces
Well if you have a kit with a standard piston that is worn out you still have a kit and you still need a piston.
08 Outlaw 525s
07 CRF70
04 Harley FLHRCI
04 TRX90
03 XR650R
02 XR100R
01 Banshee
00 XR50R
00 XR70R
99 PW50
99 JR50
96,95 Sportsman 400
95 Xplorer 400
94 Indy XLT
87 Trail Boss
86 TRX70 x2
85 ATC350X
85,84 ATC250R
85 Red Tecate
85 LT50 x2
84 XR500R
82,79 XL500R
83 ALT50
76,75,74 XL70
72,71,71,71 SL70
72 Harley FX
72 SL100
70,69 Z50
Yep... good point. I thought you might have bought that kit that xownerx had. When you said kit I assumed it was new never installed.
Bruce
I don't have it yet but I know where I can get one. How much do you think the cylinder and head are worth? What is different about the head? Larger diameter combustion chamber or what? I probably shouldn't even wast the money if I can't get a piston.
08 Outlaw 525s
07 CRF70
04 Harley FLHRCI
04 TRX90
03 XR650R
02 XR100R
01 Banshee
00 XR50R
00 XR70R
99 PW50
99 JR50
96,95 Sportsman 400
95 Xplorer 400
94 Indy XLT
87 Trail Boss
86 TRX70 x2
85 ATC350X
85,84 ATC250R
85 Red Tecate
85 LT50 x2
84 XR500R
82,79 XL500R
83 ALT50
76,75,74 XL70
72,71,71,71 SL70
72 Harley FX
72 SL100
70,69 Z50
call LA sleeve, they can sleeve it and supply a piston for it too. Most 300 kits have been bored out to the max, so they figured out how to sleeve them and supply pistons. Prolly not worth the cost though.
Haspin veteran '02, '03, '04, '05
"Hey is your dash-cam on? Are we gonna be on C.O.P.S?"
RECOVERING Trikeaholic
well both CT and TRINITY RACING has machines capable of making pistons, also trinity racing told me that they can make a piston for out dated big bore kits.
adam
86 ATC 500R the duner..
85 ATC 500R...the not quite finished faster duner
1985 ATC 250R Bone stock!!
1985 ATC250R mx/duner
1986 TRX370R MX/Duner
94 Banshee 400PV Cheetah 105RWHP
Everyone I talked to said fjor around $500-$600 they could resleeve and supply a new piston. they actually use a water cooled 330 kit to make it happen.
If the cylinder has any bores left on it you can also trim the skirts off a fl350 piston and go that route.
1985 350x
1985 350x
1985 250r
200 auto x
1984 250r
1982 250r
85 Tecate
86 Tri Z
85 TRI Z
98Wolverine
99TRX 300
Then there's two 350cc oddy's. The early version is 329cc and thats the one that should work................![]()
how much do you have to trim off the skirt on the oddy pistons to make them work? and if that works for the 300 kit, will a fl250 oddy jug and piston bolt up to a 83 R bottem end?????
1985 Tri-Z-
Originally Posted by mywifeknowseverything
I hate to bring this up, but awhile ago wasn't there a person who needed 15 more poeple so he chould have pistons made. I belieive the piston, rings, and such were gonna cost $200. Did he ever get the people he needed to do this?
