Results 1 to 15 of 21
Thread: Need to cut knobs off front tire
    Jul 2004
    Mud hill. close to water !
    3,658
    My 85 . 250sx has a 6 ply front tire and the knobs are rubbing and digging into my forks when i turn or ride an angled hill. I could change the tire to a regular trike tire, but i like the grip this one gives. and also keeps the front down ( yeah.. i know wheelies are cool, but i'm not a huge fan of breaking plastics )
    Any suggestions on the right tool for the job ?
    Watertown, New York 13601
    3,382
    A grinder.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    Nov 2004
    Atlanta TX 3-states area
    1,592
    yeah if your going to cut the tire either a grinder, or if you have a lot of time on your hands a dremel tool so you can be more presice.
    1985 Honda ATC 350X
    2003 Yamaha Banshee
    2003 Polaris Sportsman 500
    There are 3 kinds of people in this world, Those who make things happen, those who watch things happen and those who wonder what the hell happend.
    Jul 2004
    3,658
    I have a dremel, but can't even begin to imagine doing that with cut off disks.. that would take forever !!!
    I can easily borrow a grinder, i wonder how quickly the disks will get clogged up with rubber tho.
    i was thinking a blade knife maybe, have not tried yet, ( am at work and plan to do this tonight so i'm gathering ideas !! )
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    You can try unmounting it and using a razor knife, like they use to carpet and what not with. Or you can use a hot knife, probably wont like the smell though :P
    Rittman, Ohio
    6,276
    Use a razer knife. Grinder doesnt work very well on rubber.
    Jul 2004
    3,658
    Cool. i have an OLFA utility knife, heavy duty, hopefully should do the trick.
    I also have to mend my forks with some JB weld to build up the missing metal from the forks.. thank god i'm not thru them completely, they meed just where the boot meets the metal on the ruduction part.. and they wore something nasty !!! I freaked when i saw them after 1 good ride !!!!!
    Nov 2001
    B.C.
    933
    Cut the knob starting from the carcass and ending at the top of the knob. This way if you slip, you won't cut into the tire.
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Jul 2004
    3,658
    Quote Originally Posted by Mobular
    Thanks mob. tiney details can make a big difference huh !..
    Adam250sx graciously gave me a spare tire from his 81 R ( with a tube cuz it's busted up some..and quite worn ) and i was going to put that on it. but with the back bear claws it would'nt look right. I like the agressive look of the claws !!!!
    Nov 2002
    Kirkville, NY
    3,831
    Depending on how much you want to take off you might want to try a saw. I can't say that I haven't had to resort to cutting a tire off of a rim with a hacksaw before :o .
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Studytime is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2004
    Louisiana
    203
    You could just drive really fast and turn a lot and wear them off like a real man.
    Actually I would suggest plucking them off one-by-one with a very large pair of endsnips- something like a farrier uses to snip hooves. You can't accidentally cut through your sidewall this way.
    Best of luck on your endeavor,
    Studytime
    crackshot's Avatar
    crackshot is offline Worthless, would be a vast improvement. Arm chair racerJust too addicted
    Idaho
    1,024
    you need a hot knife. you plug it in, warm it up and slices them knobs off like butter or take it to a tire shop and they can slice them off with their hot knife.
    Jul 2004
    3,658
    "He said " Hot Knives " .. hmpf..." LMAO.. reminds me of college !
    Cool.. never knew that existed.
    Roanoke, VA
    4,038
    I had this same problem. The tires would wear all the way through and develope a pin-hole that the fluid would leak out of. I JB welded it several times.
    I would just use a dremel tool with the cutting disk on it.....it wont smell too good, but it should get the job done quickly.
    [20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
    Jun 2004
    Brazil, Indiana
    1,389
    use a razor blade..and only take what u need to cause the sides of the tires help alot for traction turning and ull need that
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
