Results 1 to 9 of 9
Thread: Would it be a good project?
    Dec 2002
    Missouri
    946
    I can get a 185s that has been siting in a field that has a locked up motor missing seat and back plastic for dirt cheap like $20 it has awsome tires on it. But it has full suspension do 185s have this or is a 200x with 185 plastic? I was thinking of putting a 2 stroke dirtbike motor in it i have a 125 and a 250 one laying around. He won't give it to me because he want to use the rear end to make a trailer like a small dump cart or some thing. So would do you think the motor looks like a 185s it might have some 200x forks and a swingarm grafted in there I'm confused.
    06 TRX450r , 85 ATC250r, 01 TRX300ex, 84 ATC110
    88 Mustang GT
    85200xer is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2002
    194
    I'm cornfuzed too :? If it has full suspension than it is probably a 200x with a 185 motor in it. If the motor is pull start and has a automatic tranny(no clutch lever on the handlebars) then it is a 185 motor. so to answer your question it probably is a 200x chassie with a 185 motor in it.
    85 200x, powroll 12:1 comp , race cam, barnett clutch,supertrapp exhaust, 350x suspension.
    01 800 summit, 159x2 track, dual pipes, reeds ready for snow.
    www.geocities.com/bjh200x/PHAT_TRIKES.html
    :Beerchug
    You arent even describing anything. Was there supposed to be a picture?>>>
    Dec 2002
    98
    HONDA300EX,
    Post a pick. The HONDA guys in here will be able to nail down exactly what you have. You guys are good.
    1984 Tri-Zinger, 1986 KLT 110, 1985 KLT 160, 1985 KLT 250
    No QUADS please
    Apr 2002
    s.w. michigan
    6,498
    20 dollar special
    for tweny bucks,,, get it. it's a honda at any rate. put tranny fluid in the spark plug hole, keep it full for a couple of days then try to get it freed up. maybe even cut the tranny fluid with some deisle fuel, it makes a heck of a penitrating solution. just take your time with it + you will probbly get running if just froozen up from sitting so long.
    john
    Dec 2002
    98
    Wait a minute, he won't give you the rear end because he wants to make a dumper out of it. So if you pay him $20 bucks you get the rear end?
    No QUADS please
    Dec 2002
    Missouri
    946
    Quote Originally Posted by KLT Man
    Didn't really get that ether i will try to get some pics. It has a pull start and no clutch it don't really have much supension like 2 or 3 in the back and 5 or so in the front. I think it is a 185 it looks to be welded on and hacked up kinda rigged up in there it's swing arm looks like my old blaster one
    88 Mustang GT
    Dec 2002
    98
    I hate it when the YOKLES who bought trikes in the 80's used them for more than utility work and welded all kind of farm implements on them. It makes our job of restoring theses things that much harder.
    No QUADS please
    Nov 2002
    Oregon
    65
    It could be a full suspension kit for the 185. You could buy them back in the day.
