Results 1 to 15 of 49
Thread: Tri Z Complete Frustration
    Ontario, Canada
    48
    I have a 1986 tri z and since i got it it has had this problem where it starts up for about a minuite then dies. when i try to start it right after it fires then almost dies instantly, but if i wait i can usually get about another 30 seconds out of her.i have cleaned the carb numerous times, changed the coil, changed the cdi, cleaned the fuel tank put new fuel lines on it and it still does the same old shi*!!! PLZ HELP!!!!!!!! im to the point or tearing my hair out!!!!!!!!!!!
    a-camp's Avatar
    a-camp is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Orange Co.
    420
    Check my two replies for the tecate
    Ontario, Canada
    48
    its not fuel i dont think
    i Have all clear fuel lines on the machine and it dosent seem to have a problem with fuel.
    Aug 2002
    NY
    2,652
    check the compression maybe it is low and needs a rebuild
    Ontario, Canada
    48
    got lots of compression
    Its got lots of compression my foot hurts from kicking the damn thing sooo much!
    a-camp's Avatar
    Orange Co.
    420
    What about the plug ?They could work til hot then die til it cools off. If its broke inside? Im fishing but this happend to me .And i tried everything but a second new plug for weeks.
    Ontario, Canada
    48
    ive gone through like three or four plugs and its always the same thing i even took it to a shop and they said it was the cdi but yamaha didnt make them anymore so i bought one off e bay and it still does the same shi*!
    a-camp's Avatar
    Orange Co.
    420
    I'll keep thinkin for you. Let me know how you do.
    Front royal, va
    2,186
    Take The Fuel Pump Apart And Check The Diaphrams For Tears!
    Rittman, Ohio
    6,276
    Take the gas line off the carb, and kick it over making sure that the fuel pump is working. It should squirt a bunch of gas each time you kick it.
    Ontario, Canada
    48
    ive put new diaphrams in the pump.I have also put all clear fuel lines on so i can watch the fuel flow and there is no problem with that.
    Jul 2003
    Ontario Canada
    813
    is your carb not set right??
    i dont know much bout Tri Z, so my opinions are long shot.... but i know its a ***** to tune 2 strokes
    Curtis
    Currently Trikeless- but I have a LT250R
    Anaheim
    1,270
    just cause u have top end compression doesnt mean trailprotrailpro bottom end is holding compression. also i had the same problem be4 my R blew up, mine had perfect compression when u kicked it but when it started it would loose it all. also check the reeds.
    adam
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    wolfspider's Avatar
    wolfspider is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    HARROGATE, ENGLAND
    376
    tri z
    this sounds like a choke problem to me, it starts ok then dies because it doesn`t need that much fuel anymore when warm.
    i would take the choke lever out and clean it , maybe blow some carb cleaner and compressed air through it.
    hope this works.
    steve.
    HONDA ATC250ESJ 1988
    HONDA 250R `85 restored SOLD
    HONDA ATC 350X `86 restored SOLD
    HONDA ATC 250ES `87 SOLD
    YAMAHA YZ100 `80 project
    HONDA ATC350X `85 PROJECT FINISHED
    Rittman, Ohio
    6,276
    Still sounds like gas delivery to me. While youre in the carb, go through the whole carb, pull all jets, blow out all orifices, and pay close attenting to the the float needle. If the needle sticks upward it will do exactly as you describe. Gas enters float bowl at a drip, and when its been sitting, and the float bowl is full, it works fine until runs long enough to empty the bowl.
