PowerTrike.... I have a scrambler as well, so good luck w/ it. I have had no problems yet w/ mine so i don't have any advice to give you yet. BUT w/ my Tecates I can tell you that when the needle sticks in my carb, gas leaks into the carb and into the cylinder/ base. When you get fluid in the base you get fluid locked, the liquid gas does not compress and it will stop the motor from running rite or at all. I took my T3 apart and turned it upside down to let the gas drain from my plug hole (I didn't want to pull the motor apart and put new gaskets in), it worked for me. I looked at the Scrambler manual and it has 8 pages on the carb alone, nothing looks different from any other 2 stroke carb I have seen. You might want to get ahold of HOWDY he had another copy of the manual that might be for sale. I was told that the starters do go bad pretty easy, I'd bet thats the problem. I'd try to hit it w/ a 12 volt jumper wire and see what it does.
GOOD LUCK W/ IT
KEEP US INFORMED
MIK6 / Mike
New England Ride 4/13
