Results 1 to 12 of 12
Thread: Removing Paint From Fenders???
    Nov 2004
    Dunbarton NH
    27
    Anybody know the best solvents to use? what to apply/scrub with? Any help would be great!
    -mike
    1984 YTM 225DXL- in process of complete restoration
    http://www.ytm225.tk for pics
    Jul 2004
    Mud hill. close to water !
    3,658
    do you know what was used to paint them ?
    Nov 2004
    Dunbarton NH
    27
    looks like it's just regular spray paint because its all chipped up
    Jul 2004
    3,658
    Varsol or Methyl Hydrate should do the job.
    soft bristle brush, and lots of fresh air and no sparks !
    Nov 2004
    Dunbarton NH
    27
    Thanks, I'll pick some up and see how it works. When you say soft bristle brush do u mean with nylon bristles?
    Jul 2004
    3,658
    Even a rag would do, should rub right off with solvent.
    a shoe brush, or kitchen nylon bristle brush would also work.
    you don't want to gouge your plastics.. just remove the paint.. i'd soak a rag with solvent, and let it sit on there for a minute or so.. with any luck badabing !
    test a spot under the fender before you go do the whole thing at once just in case.
    Jul 2004
    3,658
    epoxy thinner also works wonders on paint, but be careful not to melt your plastics... strong stuff ! use sparingly !
    Nov 2004
    Dunbarton NH
    27
    allright, thanks
    -mike
    Mar 2004
    Newnan, GA / Near Atlanta
    1,727
    I have herd that easy off oven cleaner works good. I personally use a sidegrinder. LOL Just kidding. I dont paint my fenders. I buy new ones.
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    2008 Yamaha Rhino 700 SE
    Apr 2002
    s.w. michigan
    6,498
    solvents
    brake fluid will also soften up paint with out hurting plastic ,,,
    john
    Studytime is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2004
    Louisiana
    203
    Not to sound like Mr. Safety, but depending on what you use you stand a chance of burning your skin.
    Try gettin Aircraft Remover on your exposed skin. You'll know exactly what I'm talking about.
    If you are working with some sort of chemical remover with a high basicity, then certainly make sure you have on goggles and rubber chemical gloves.
    Studytime
    Jul 2004
    3,658
    I assumed that was obvious...... maybe i shoulda not assumed.
    For god sakes, wear gloves at least.. surgical gloves will work for a short amount of time, but they disintegrate quickly.. thick rubber fisherman's gloves or like above chemical gloves should be worn for anything stronger than methyl hydrate !
