Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Thread: Got My New Trike
    Nov 2004
    Louisiana
    31
    Was just wondering. My ex detenates with anything less than 93 octane, and its only at 11:1.
    '01 406ex, 11:1 compression, ported & polished.
    LOTS of Honda 3-Wheelers!
    Aug 2004
    Ab Canada
    4,368
    yea it should detonate with anythin less than 93 octane i would think, as for reliability on the 12:1 piston....seems ok my biggest concern is that race gas is expensive and the 200 is kinda a pig on gas alredy...and it will run hotten, if you where lookin to build the bike i would recomend a 10:25:1 compression piston, gives a suffciant gain but still dosnt heat up much
    1985 Tri-Z-
    Studytime is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2004
    Louisiana
    203
    I don't think 150 octane even exits or is possible.
    If you started with 87 octane you might have ended with 90 at best. What kind of octane boost are you referring to? Most are very poor at raising octane- that is, if it comes in a 16 oz bottle.
    If it ran on that then it will probably run on supreme.
    Studytime
    Nov 2004
    Louisiana
    31
    that would be my recommendation also. Especially if you ride alot of trails. Around here in southern Louisiana, trail riding means slow moving and muddy; not very good conditions for an air cooled motor w/ 12:1 compression.
    Aug 2004
    Ab Canada
    4,368
    heh, well the 150 octane, it said 1 point per every liter per oz or something....it was only like a 2 liters of 87 octane then he added i think it was either 500ml or a liter of 108 ocrante boost...i dunno my friend said somethin about 150 or something....lol i dunno, it must have been over 102 octane at least or elses it would ping...and if anything it was rich and way to much octane....ill find out for sure tommrow
    1985 Tri-Z-
    Nov 2004
    Louisiana
    31
    The thing about how companies rate octane boost is that when they say 1 point they mean .1 points added to octane rating. so 16 oz at 16 liters using 89 octane to start = 89.1. Maybe the type you have is different, but read the fine print because 99% of them are a waste. They do clean the fuel system rather well though.
    Nov 2004
    Louisiana
    203
    Quote Originally Posted by My trike Sucks
    I didn't follow all of that, but you don't understand how that works. One "point" is equal to .1 gain of octane. If it raises your octane "5 points" that means it went up 1/2 point from say, 87 to 87.5.
    This is how it works. Most of the OTC octane boosters are nothing but toluene. I suggest you reread the label.
    Oh, and you in no way have "too much" octane by adding that.
    Studytime
    Aug 2004
    Ab Canada
    4,368
    ha....learn something new everyday.....as i said i need a thing under my name that says"villiage idiot" =)
    1985 Tri-Z-
    Nov 2004
    Louisiana
    203
    Oh, and that apparently wasn't even pure toluene which has a (RON+MON)/1 rating of 114 octane.
    Anyway, if it ran that way like you say and didn't detonate, perhaps he doesn't need race gas.
    Good luck,
    Studytime
    Nov 2004
    Louisiana
    31
    no one knows everything. Matter of fact, its usually those who claim to know it all that really know nothing. Glad you didn't get offended that we corrected you. It's only constructive critisism.
    Nov 2004
    Louisiana
    203
    Quote Originally Posted by mwill15
    Exactly! I sure know I don't know everything. No offense meant at all.
    Studytime
    conig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    tallahassee FL
    392
    chap250. most definately the 2.5 inch spacers I put on my big red have worked wonders. just keep in mind the width and your riding area. It makes it easier to nick trees.
    1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
    1985 honda es 250 big red.
    85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
    A trike to show up the modern utilitys
    2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
