Results 16 to 30 of 36
Thread: Finally pics of stripping the X down
    BigTBones's Avatar
    BigTBones is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Salem, Oregon
    420
    can anyone answer my question?
    Quote Originally Posted by BigTBones
    Everything came apart pretty easily but i did break 2 bolts that i will need to replace. The first one was the top by the motor mounts that holds the skid plate on. It broke inside the frame! opps! The other one i got out. I have a couple of questions to ask. Where and how much are motor bushings! I also need everything inside the neck of the frame ( bearings etc). One more question. Before it was taken apart the lights wouldnt come on with the engine running. I tested everything and there was no electricity coming out of the voltage regulator. Is there supposed to be elctricity coming out of it??
    Motor bushings??? Are you talking about the spacers for the motor mounts on the long bolt? Or the rubbers on the skidplate?
    Dads over at org can help you with bearings, he has a sticky in the classifieds, might as well convert to the taper neck bearings.
    Yes there should be power coming out of the regulator, but if the regulator is bad it would blow your bulbs. I'm kinda talking out my rear when it comes to electrical, could be the switch, bad wire in the harness. or just bad bulbs.
    If you don't want to buy online, Rob at Cycle Country in Salem is pretty helpful. He used to be a 350x rider until the 450r came out. lol
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    BigTBones's Avatar
    Salem, Oregon
    420
    ya im talking the spacers. There was 2 i think and one broke into 3 pieces! How much would that cost to buy new ones???
    BigTBones's Avatar
    Salem, Oregon
    420
    ok its been a while since a have posted anything on this thread so i thought i would share my progress. Here are a couple of pics that i took this morning.
    Attached Thumbnails Attached Thumbnails Picture008[1].JPG   Black 1.JPG   Black 2.JPG   black3.JPG   Black 4.JPG
    Jun 2004
    geraldton, west australia
    1,068
    pretty smicko...keep em coming
    LIVELOVERIDEDIE
    1981 Honda Atc 124R-Racer project
    2005 Giant STP 1- rollin' on 26's
    Ontario, CANADA
    4,538
    that thing looks awesome, I love the little head pipe! and its going to be all black I presume?(fenders and tank and seat?)
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Jun 2003
    englishtown NJ
    2,676
    I started stripping down a 350x I bought yesterday, I got down to the axle(can't get the lock nut off), head pipe(typical rust jammed), and the front axle is rusted in. all those I need more mapp gas for, I'll have some before and after pics soon.
    BigTBones's Avatar
    Salem, Oregon
    420
    Actually Kintore its totally the opposite. Its going to have a white rear fender, a white front fender, a white clarke tank, white super tank scoops, and a black seat. Oh and what color do u think would look good as the headlight assembly?? I was thinking either black or white??
    Aug 2004
    Ab, canada
    1,222
    Looking good man! Get some clothes on that trike!
    Rides:
    82 atc 200e
    83 atc 200e
    76 chevy k20 custom deluxe
    01 ford f250 diesel
    1938 Nash Lafayette
    1925 Nash Ajax
    My band:
    www.myspace.com/epicosgiliath
    BigTBones's Avatar
    Salem, Oregon
    420
    Exclamation
    Ya, I have been told that the head pipe is a bassani or a dg?? Im not sure exactly what it is. All i know is that it isnt stock because on the stock header the heat shield mounting is set up different than this header! Can anyone tell me what it is?
    Cool looking bike! Its going to look like mine. Its about due for a makeover though. I need to get my frame to the powdercoater.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    BigTBones's Avatar
    Salem, Oregon
    420
    I think I am going to go with the black headlight! I do need a set of new lenses & bulbs for the head light. Anyone know acout how much this will cost me??
    Jan 2005
    Slatington PA
    4,372
    Great restore job! Good work!
    I'm a white freak myself and think you should keep the flow going and stick with a white headlight.
    Another suggestion would be to PC or just paint the lower fork legs white & inbetween the the triples white. That would really look great (in my eyes anyway) and make the front end look quite different then anything else.
    Agreed or not your project looks great!
    Oswego, IL
    1,858
    blazer where u get them tank stickers?
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
  15. #30
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by BLAZERONE22
    Yours looks great too and have a ?. The rear plastic looks like there is no indentation in the mold for the kick start to go in proper. Is that correct or is that an illusion?
