Results 1 to 15 of 22
Thread: ESR powervalve cylinders...
    Ventura, CA
    87
    I love my totally stock 86 250r (the only aftermarket items are the rear tires and a K&N filter) but, let's face it, I can always use more power. I was thinking the CT 310 kit, but was told the ESR powervalve was the way to go. They have a 265, 310, 330, 350, and 370. But the 330 on up require a long rod. I want to keep the bottom end as stock as possible so long rod is out of the question. Anyone have comments about the powervalve top ends vs. the CT kit? 265 vs. 310? I ride mostly dunes and desert; It's the only good thing about living in California I'm just looking for the fastest, most reliable set up. And it should be free on my birthday!
    Mar 2004
    Eastvale, CA
    630
    I don't have any experience with the power valve cylinders from ESR or CT, but I do have a non-power valve ESR 310 kit on my R and love it. A friend has the same 310 kit from CT and I smoke him all day long in the dunes and on the hill. Both cylinders are made by Pro-X, but ESR and CT have different porting set ups. Where in CA are you located and where do you usually ride?
    Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
    Wife's Ride - 2009 Polaris RZR 800
    Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
    Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
    got sand?
    Anaheim
    1,270
    same question for me i would like to make more power and wats the cheapest set up and best horses?
    adam
    86 ATC 500R the duner..
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    Mar 2004
    Eastvale, CA
    630
    Porting will be the easiest and least expensive, but to have it done right plan on spending $150 minimum plus the cost of other mods such as reeds, pipe, carb, etc. You can also bore a stock 85 or 86 R cylinder to 69mm for a pretty wild 270cc sleeper motor, but if you take it that far you won't have any overbores left.
    I believe non-PV big bore kits start at about $800 for a water pumper.
    got sand?
    Apollo is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2004
    Fort Worth, Texas
    190
    I was wondering about the ESR and CT comparison. That settles it, I going with an ESR 310 powervalve kit. Especially since I already have an ESR reedcage and pipe. Badpig, I highly recomend the ATC 5 pipe and The RB2000 reedcage. Get a 38mm or larger carb also. You are going to love it!
    Nov 2004
    Fort Worth, Texas
    190
    I forgot about the ESR silencer, I think it is the ATC M or something. It is hard to slip on the pipe though. But way worth it, and it sounds awesome.
    Jun 2003
    englishtown NJ
    2,676
    I have the pipe/silencer, I found its a bit tough to get on right, I had to cut some spacers and such and when I switched to the 86 frame, I had to put exhaust hangers to move the silencer in about 1/2. Another expeirence of mine is that it didn't fit on the bike with the skid plate one, when I switched to the spacer plate motor , I could use the skid plate. It really didn't bother me much as I don't have any skids on my trike(strictly mx). I had a esr330, and I wanna buy a 265 pv. And also I use a 38 a/s carb and a cr 250 igintion.
    a-camp's Avatar
    a-camp is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Orange Co.
    420
    Whats wrong with FMF pipe just bolt it on and go faster?
    Nov 2004
    Fort Worth, Texas
    190
    The skid plate does not fit with esr's pipe, now that I remember I had to space my silencer out almost a quarter inch to clear the shock even though I probably did not have to, just felt better doing it. I'm going to cut out a small section of my skid plate so I can put it back on. It was hell getting the silencer to slip on the pipe, it was like the silencer was to small in diameter for the pipe. All in all, I am very satisfied.
    Ventura, CA
    87
    Thanks guys, that settles it. I'm gonna pick up the ESR 310 powervalve kit. Just have to wait til after christmas. And Sandman, I'm in Ventura. I normally ride Pismo, Gorman (hungry valley) or riverbottoms.
    Nov 2004
    Waterloo IL
    2,701
    I had to trim my skid plate to fit the ESR pipe on my 85. Other than that (not that, that was anything) the fit, quality and performance gains were excellent, very happy with it.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Fresno Ca
    2,695
    Quote Originally Posted by badpig121
    Are you going with us to pismo in jan? ESR is the way to go, ESR products all the way. Eddie knows his S***. Some of my friends dads raced for him in the 80's, and there still getting special work done from him.
    Ventura, CA
    87
    What dates in Jan? I'm working weekends right now, but I will be switching to weekdays in the middle of Jan, so I will have weekends off for the next six months .
    Mar 2004
    North Central Ohio!!
    2,712
    How does the ESR pipe act? Is it smooth, or does it hit real hard in the middle?
    Fresno Ca
    2,695
    Trip to pismo is the last weekend of Jan. Go to the local riding section for more info. Hopefuly well see you there.
