Results 1 to 8 of 8
Thread: 85 250sx ignition ?
    mikey's250sx's Avatar
    mikey's250sx is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    lancaster, pa
    417
    85 250sx ignition ?
    since i don't have a key for the elec start and my local dealer wants 50 bucks for a new cylinder and key can i just pull the cyl. out and jump some wires together to bypass it altogether. making the start button hot all the time?
    thanks
    Mar 2004
    Newnan, GA / Near Atlanta
    1,727
    I wouldnt reccomend it. The guy I got my 250 Big Red from did that and screwed more stuff up. Shorted a couple wires and componets. Call a salvage yd or watch ebay. They go for about $30
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    2008 Yamaha Rhino 700 SE
    Nov 2004
    lancaster, pa
    417
    will an ignition from a 125m work? i can just swap ign. cylinders right?
    asc180's Avatar
    asc180 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2002
    Howard City, MI
    209
    Just hook up a toggle switch in there. It Doesn't pass that much current through the key switch so a normal auto one should work.
    Adam
    Adam
    89 LT500R-
    85 250R- Project-
    85 250sx-
    83 185s
    80 act70
    Nov 2004
    lancaster, pa
    417
    thanks. i'll give that a try.
    i may still get the 125 ignition. it is on ebay for a dollar with a key. if that doesn't fit i will get a toggle.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by mikey's250sx
    A TRX125 ignition can be modfied to work. The difference is in the plug connector. If you have your 250sx ignition switch you can just change the wires over.
    Howdy
    almac16 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2004
    Halifax, Nova Scotia, Canada
    226
    Pretty much anything will work if you are willing to cut some wires.
    I have a 1978 Enduro 125 key/switch on one of my 250sx's. I was always staying out at the camp and I had to get a key on it so no one would take my bike for a spin.
    Apr 2002
    s.w. michigan
    6,498
    custom
    here is what i done on a 200es ,,, eleinated the reverse light also.
    john
