Results 1 to 13 of 13
Thread: Mush Forks
    a-camp's Avatar
    a-camp is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Orange Co.
    420
    Mush Forks
    My front end is mush on my 86 250r. I was going to purchase a set of Progessive springs next year. 3rd on list. My friends tell me to drop short cuts of PVC in tubes for now to use as bushings. Could this work ? Or will they split?
    Jun 2004
    geraldton, west australia
    1,068
    they should hold for a while, definately long enough to get some better springs
    LIVELOVERIDEDIE
    1981 Honda Atc 124R-Racer project
    2005 Giant STP 1- rollin' on 26's
    Dec 2002
    Kansas
    2,387
    I done the pvc pipe trick to my 250r. I took a fork cap with me to the hardware store so I could get the biggest diameter size possible. I bought couplers since they are thicker then just pipe. I cut each 1 to 1 inch long. It was the best, cheapest upgrade I ever done to my 250r. I would have put longer pieces in but couldn't get them shoved in without lots of trouble and probably a black finger nail.
    I had the RIGHT to remain silent, I didn't have the ability!
    Nov 2004
    Waterloo IL
    2,701
    What exaclty are you guys talking about?
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    a-camp's Avatar
    Orange Co.
    420
    Front spings on my bike are mush . My bike sits low in the front.I headr if you put s
    small pieces of PVC in your fork it will compress the spings and lift you up.
    Thanks for the replie.
    Rittman, Ohio
    6,276
    Its called preload, and it does the same thing as adjusting the large nut on the rear shock. When you buy progressive springs from Dennis Kirk they are packaged with two standard PVC pipe pieces a few inches long that you can cut to desired length or leave out altogether.
    May 2002
    Cortland, NY
    1,195
    I did that trick to both my tri z and 350x since those trikes have soft front suspensions. What shape are your fork seals in (do they leak)?
    http://photos.yahoo.com/dynofox250 (TF 03 pic's)
    Trikes: Restored '86 ATC 250r, original and mint '83 185s
    Quad: '86 TRX 250r
    Sled: Rev X 800ho mod
    Bike: '00 ZRX 1100
    TF '03 and '05 Survivor
    a-camp's Avatar
    Orange Co.
    420
    My seals are new . Been trying different oil levels and weight. Im at 450cc per ? Is this good. Anyone know what weight on oil.
    a-camp's Avatar
    Orange Co.
    420
    I did it . I used a 1inch sch80 nipple . I found one with no seams and cut two 1 1/2 inch pieces out of the center. It lifted the front of my bike nice . We will see what happens when I jump.
    May 2002
    Texas
    2,670
    The PVC should be fine from now on, but if your that worried about it use aluminum tubing for your pre-load spacers.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    sandrooster is offline At The Back Of The Pack Arm chair racerFirst time rider
    mom's house
    193
    Quote Originally Posted by a-camp
    ... Anyone know what weight on oil.
    The sag is from worn out springs.
    I use Belray 10wt fork oil in one of my 85Rs. It seems to work the best for all around riding.
    In the other 85R, I tried 5 than the 7 weight fork oils because I ride alot of high speed washboards. On the washboards at speed, the lighter oil gives the forks the feeling of quicker response. But I really don't like to get serious air on this one cause the forks bottom. This is with no air pressure.
    So 10wt to start is my recommendation.
    85 ATC250R
    Rittman, Ohio
    6,276
    Quote Originally Posted by sandrooster
    Its refreshing to see advice given by someone who understands suspension!
    Oil, springs, and preload, optimum is as light as you can possibly go without frequently bottoming out.
    Preloading worn out springs to eliminate sag is a bandaid, not a performance modification. Preloading progressive springs is for the purpose of selecting the begining spring weight for your compression range. Use as little as necessary, none of possible.
    Heavy oil retards fork reaction. It does not make them stiffer, but it will sure make them ride rougher. Go as light as possible. Use the MFG recommended amount. Your not going to gain anything by adding more, and if you add too much, it will blow out your seals, because oil cannot compress. You can only loose some of your dampened range of extension by running less.
    Air pressure should be at 0. Adding a little air can help compensate for weak springs, but its a crappy substitute for proper spring length, and stiffness. It too is a bandaid, and not a performance modification.
    a-camp's Avatar
    Orange Co.
    420
    Sounds good I am running 10 w after trying several different weights . I also am back to 450cc per as you saggested. I found with to much it feels like your bottoming out if your seals hold. Thanks for good input.
