Thread: Question for anyone that has upgraded to a 200x carb on a 185s or 200s.
    StangLX302's Avatar
    StangLX302 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    302
    I just won a 200x carb on eBay and it should be arriving soon. Anyways, does anyone know what main jet I'll need to start out at? Do I just leave the stock 200x jet in there and go from there? Will it run OK (for testing) with the stock sized 200x jet? What about the needle clip setting?
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -Air filter box removed
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
    -200s front forks/shocks
    -Aftermarket 4 bolt rear wheels
    -Tire chains when ice riding
    1988 Ford Mustang LX 5.0L
    -Wayyyy too much to list!!!
    May 2002
    610
    I have never done this, but I don't see the difference in air/fuel ratio requirments between these two trikes being very different (when all else is stock). What size carb is the stocker on the 185/200s? The stock settings should be ok for a test run, I would think. Maybe someone else knows something more definite.
    Sam from Florida
    1985 BIGRED $ 200X
    StangLX302's Avatar
    Jun 2003
    302
    I was looking for an answer from someone that has actually done this.
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
    Nov 2001
    B.C.
    933
    Stock 185-200cc carbs are 22 mm. The 200X carb is a 24mm. There may be exceptions, but these are the usual carb sizes for the spacified cc ATCs. I have a totally stock 200x carb on my 200M. Didn't change a thing on the carb....but then, the 200m does have a 200X piston and cam.......
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Studytime is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2004
    Louisiana
    203
    [QUOTE=StangLX302]I just won a 200x carb on eBay QUOTE]
    Why didn't you go for an XR carb? Good luck. I also predict your X carb should run close with it adjusted to stock X parameters.
    Studytime
    StangLX302's Avatar
    Jun 2003
    302
    [QUOTE=Studytime]
    Quote Originally Posted by StangLX302
    Studytime
    I didn't want to jump up too much all at one time. Maybe I'll get that one later when I do some more mods to this lil 185. The great thing about eBay is that you can buy something, use it for a year, then get back what you paid for it.
    I'll try the stock X settings first, then pull the plug and check it out. Thank you.
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
