Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Thread: loose chain
    Rittman, Ohio
    6,276
    Quote Originally Posted by 85 250sx
    ok i tightend the chain and i tightend it as much as i could and i ended up with about an inch of travel so hopefully it wont fall off any more i was wondering if the 86 250r's came with chain guides because mine dosnt have any and do they realy help?
    Chain guides work great, as you rarely hear of a Yamaha throwing a chain. I dont know why Honda didnt use them, but they should have. They are not a subsitute for a good fitting, properly aligned and adjusted chain though.
    Mar 2004
    Gettysburg PA
    498
    are chain guides hard to come by or where can i find them?
    Rittman, Ohio
    6,276
    They have aftermarket ones, but the problem is to put one on right requires welding mounts to the swingarm, which is why you dont see them very often.
    Aug 2002
    Creswell, OR
    889
    Chain guides are still available. I had all mine replaced when I redid my swingarm. Plus I put Yamaha's idea on mine as well. One is a side view of it, the other, is the unfinshed swingarm but a good pict of the added guide. I had mine extended so I felt this was a great addition. The front of the swingarm you should be able to get the guides.
    www.3wheeler.org
    * * * Nothing scares me more than someone who knows, with certainty, what is best for me * * *
    Mar 2004
    Gettysburg PA
    498
    i found some after market guides at
    http://www.rockymountainatv.com/Mach...r=1986&status=
    whats the diffrence between the two? they look totally diff
    Mar 2004
    Gettysburg PA
    498
    can some one tell me whys these are differnt and where they go? thanks
    Phoenix, AZ.
    6,719
    The first one is just a stock replacement that goes over the swingarm (towards the front of it). The other... hell if I know. First time I've seen one like that. I was thinking it replaces the stock roller that's attached to the frame above and behind where the first one goes but I'm not sure.
    Mar 2004
    Gettysburg PA
    498
    do i realy need a chain guide? like will my chain be falling off all the time if i dont get one? or are they just nice to have for those few times it does fall off? how many of you guys have them or how many of you dont have them for thos who dont have them do you chains fall of often?
