Results 1 to 8 of 8
Thread: 1973 atc 70
    Dec 2003
    1973 atc 70
    I had a buddy drop off a 1973 atc70 that looks to not have run in some time. The tires are dryrotted in one spot like it sat for 15 years, the fuel tank is original with orange paint and flames,has some rust inside but very usable!!! I removed the engine and disassembled down to bottom end and all looks real real good. The exhaust is stuck in the cylinder head,I got both 10mm nuts off but the pipe is rusted in head. I am still working on getting that out with out breaking exhaust or head casting!!!So the carb was filled with the most horrible gas i had ever seen!!!I cleaned most of it real good and got the slide working in the carb and now all I need for the carb is a float. I am missing the pullstart and can only get spark out of the stator occasionally!!!I really want to get this 70 running ,I just need to know what parts are interchangable with a 73 atc 70???!!! Any info you guys can provide will be greatly appreciated!!!!! Rob Fletcher
    1973 atc70,1986 350x,1997 xr70,1985 atc 70,86 200x,99cr 250,90dr 350,1989=702 hp mustang
    Nov 2004
    Waterloo IL
    2,701
    Off topic, what is all done to your Mustang?
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Dec 2003
    well that is a broad stroke,but i will try. 1989 gt Dart block 331 scat billet crank /h-beam rods, J/e 8:1 pistons,s-trim,aftercooler,Gen VII dfi tuned by turbo people,72 lb injectors,edelbrock rpm heads and intake,50 shot zex,tremec tkoII ,spec stage 3,8.8 with 31 spline moser ,spool and cclip eliminators. 8 point roll bar ,subframe connectors, aeromotive full fuel system with sumped tank,msd 6al, dual sync distibutor for sequential fuel injection,comp cam nitrous grind!! There is much more going on!!! I ran 11.20 at 131 with a 1.8 60 foot!!! All I have to do now is learn how to drive this thing.
    Nov 2004
    Waterloo IL
    2,701
    Sweet, that's more than what I've got.
    Still running the stock block (that's gonna cause problems). DSS 331 short block, ported canfields, Holley intake, 42lb injectors, D&D Viper 6-speed, Anderson cam, clutch, PMS, power pipe, 80mm MAF, 70mm t-body, 8-point chrome moly cage, chrome moly k-frame w coil overs. Cobra brakes all around, 5-lug wheels. Still running A/C. I put 516 hp to the wheels at Anderson Ford. I was running out of fuel and did not have the heads ported and had shorties with 2 1/2 in exhaust. I have a new 10 an fuel system, got the heads ported and switched to long tube headers with dual 3 inch and an off road X-pipe. Havent had it at the track yet but I'm hoping for deep 10's.
    Oh yeah good luck with the ATC70. Sorry to whore your thread.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
    mad_max is offline Just Too Addicted Arm chair racerJust too addicted
    Kansas
    462
    quik, you have to be careful with 70's as they made slight changes from year to year. Seems like pullstarters changed every couple of years. I'd say you'll be safe with 1974 parts but the later 70's probably wont fit. 73-74 are kind of unique. Get ahold of jenndnn3, she may be of some help. Oh, if you wanna get rid of that 73 let me know
    Dec 2003
    As far as I know the pull starter is interchangable between my 85 and 73. I know for sure the carbs are different,like the float on the 73 is completly different from the 85. The complete carb might be interchangable though. These are the things I need to know, I wanna run this 31 year old atc!!!! Hey blown331 you got a sweet combo there. loving that 6speed i bet. I love blue oval performance!!!!! How do I get in touch with jenndnn3????
    Kansas
    462
    Quote Originally Posted by quik5.0
    Send her a PM (private message)
    Or contact crnacnac, he just did a ground up restore on a 73' that is the best most complete restore I've ever seen in my life. And I'm a 70 nut. Trust me, check this 73' out. Its insane nice. Maybe to nice.
