Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Thread: Does anyone here have this DG exhaust on their 185s/200s???
    StangLX302's Avatar
    StangLX302 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    302
    http://www.denniskirk.com/jsp/produc...Id=&leafCatId=
    How do you like it? How was the fit and quality? How loud? Most importantly, do you have any pics of it installed?
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -Air filter box removed
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
    -200s front forks/shocks
    -Aftermarket 4 bolt rear wheels
    -Tire chains when ice riding
    1988 Ford Mustang LX 5.0L
    -Wayyyy too much to list!!!
    StangLX302's Avatar
    Jun 2003
    302
    Almost forgot: Does it mount inside the frame like stock, or outside like Cobra?
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
    Apr 2004
    International Falls Minnesota
    546
    Its pretty loud and it mounts inside the frame like a stock muffler. But it should give you a very noticeable power increase.
    StangLX302's Avatar
    Jun 2003
    302
    Thank you, Anyone else?
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
    StangLX302's Avatar
    Jun 2003
    302
    Well, I went ahead and ordered it from www.Denniskirk.com. It should be here tommorrow. I'll let you guys know what I think.
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
    Nov 2004
    Waterloo IL
    2,701
    My brother has it on his 200S. He said it added a little bit of power. Normally that's hard to believe from a DG system but the head pipe is a lot bigger than stock.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Anaheim
    1,270
    i had a cobra on my trick 185s and it mounted in frame but that thing was LOUD BRRRRRRP!!!!!. the only thing is dont get mud on that black cause then trailprotrailpro paint gets stained
    adam
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    Jun 2004
    Brazil, Indiana
    1,389
    i was gonna get that one..or the jardine stalker system
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
    StangLX302's Avatar
    Jun 2003
    302
    Well, it came last night. The quality looks to be good so far. I can see the paint lasting about five minutes though. I will install it some time this week.
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
    Aug 2004
    Ab, canada
    1,222
    Those will fit a 200E right?
    Rides:
    82 atc 200e
    83 atc 200e
    76 chevy k20 custom deluxe
    01 ford f250 diesel
    1938 Nash Lafayette
    1925 Nash Ajax
    My band:
    www.myspace.com/epicosgiliath
    StangLX302's Avatar
    Jun 2003
    302
    OK. Here is what happened. The bracket on the muffler was welded in the wrong spot. I had to bend the bracket and rig it up a little. I had to drill the threads out of the mounting hole on the frame and use a longer bolt. I also had to put it BEHIND (looking from the back of the bike) the cross brace instead of the front (again, looking from the back) like its supposed too. It's on there really solid though.
    2nd thing: The header was not bent exactly right. I had to put a ding in it where the top rear motor mount bolt is with a ball peen . It's still resting on it and could probably use another whack. I don't think putting a ding in it affects performance one bit, because the header pipe is MUCH bigger than stock. Then I had to bend the end of the pipe that hooks to the muffler up a little.
    Yeap, I was right about the paint. It instantly started frying when I started it.
    I really like the sound. It might be too loud for some, but I usually run it out in the middle of no-where. I don't think the trees will mind.
    I took it for a very short ride. I live in the city, so I can't run it for more than 2 minutes here. It sure did seem to have a NOTICABLE improvement in take off. I could only run through first and second gear though, I have a small yard and have already had a talking too by the cops about ripping up and down the street on it. I'll take it out to the country next Monday or Tuesday and let you guys know.
    All and all, I guess it's not that bad for a $100.00 exhaust.
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
    StangLX302's Avatar
    Jun 2003
    302
    BTW: I'm running a #100 main jet (95 was stock) and the needle clip in the third groove (2nd groove was stock) and the pilot screw out an extra 1/2 turn. This seems to be about the right calibration for this pipe, but I'm going take a wide open run and double check.
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
    StangLX302's Avatar
    Jun 2003
    302
    Quote Originally Posted by Pistonhead
    I'm not sure. You can just go to www.denniskirk.com and look up exhaust systems by year and make.
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
    Studytime is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2004
    Louisiana
    203
    So, how about some pictures? Why did you decide to go with DG as opposed to the Cobra system?
    Can you get us an approximate diameter increasein the head pipe. I know the stock one is rather small.
    Oh, you're going to run out of stuff to do that little 185 if you keep this pace! Have you serviced the clutch yet?
    Studytime
    StangLX302's Avatar
    Jun 2003
    302
    Ok. I'll get some pics up soon. I'd do it right now, but it's dark out.
    I'd say it's at least 3/8" bigger, maybe 1/2". It looks HUGE next to the stock pipe.
    Nope, haven't messed with the clutch yet.
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
