Results 1 to 9 of 9
Thread: hydraulic clutch
    May 2004
    East Coast
    58
    hydraulic clutch
    hey my 250r clutch lever is very hard to pull in and kills my had when always clutchin and i wanted to put a hyraulic clutch setup on it but they only make one for the 86 trx250r. does anyone know if this one will fir? I think it will cause it has the same motor.
    Billy Golightly's Avatar
    Live Oak, FL
    15,068
    Is your cable new? A $20 new cable and a few hours worth of oil soaking work almost as good as hyrdraulic and doesn't cost $200 either
    a-camp's Avatar
    a-camp is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Orange Co.
    420
    Yes I have been wondering that for 2 years.I use a 3 position easy lever.And a new Motion Pro Terminator cable and it is at least 35% easyer.Dont ever plan to sell my trike so I am thinking obout the hydraulic myself .
    Oswego, IL
    1,858
    when u get a new cable do u need to lube it? if so how do u do this?
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    Live Oak, FL
    15,068
    You dont have to, but it sure helps. In the past I used thin airtool oil. Just hold the cableand pour a little down in the housing between it and the cable, work the cable back and fourth, and keep doing it till it runs out the bottom. But, recently someone on the forum here suggested just throwing it in a bucket of old motor oil over night and letting it sit, that worked real nice actually. The 89 TRX250R clutch update kit is suppose to make a phenomenal difference in pull as well. I haven't did it in mine yet but I keep thinking about it. I think ChrisD and few other guys have done it.
    Nov 2004
    Waterloo IL
    2,701
    Here is how I lube them, even if they are so rusted they barely move.
    Clamp a hose over the top of the outside of the cable. Fill the hose with transmission fluid or what ever you want to use. Then put compressed air to the hose. If the cable is in really bad shape clamp the air gun to the hose and clamp the handle down. If you leave 100 psi on it over night and the oil doesn't come through its time to buy a new cable. Use common sense, dont blow the hose up.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Apollo is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2004
    Fort Worth, Texas
    190
    I have heard of this 89 trx clutch update, what exactly is it? Is it a stronger clutch, lighter pull, etc.? It works on ATC?
    Live Oak, FL
    15,068
    I dont know exactly all the details, but it replaces the stock mechanism for pushing on the pressure plate and releasing the clutch. If I can remember right, the pre 89 ones have a rod that goes through the case from the clutch actuator on the left, and then it pushes on the pressure plate. The 89 kit has this rod with a ball or something on the end that is suppose to give more leverage and will not wear as easily as the rod (Which makes it where you have to give yourself full adjustment to make any pull). I'm pretty sure Nac's Racing offers the 89 update kit for around $90.
    250rAL is offline Just Too Addicted Arm chair racerJust too addicted
    Sabula,IA
    619
    Quote Originally Posted by 3wheelrkid
    It should work provided the clutch cables on the two machines are about the same length. The only reason it wouldn't work is if it's too short to reach on the ATC.
    __________________
    '85 ATC250R
    .030 Over Wiseco
    FMF Pipe/Answer silencer
    36PJ Keihin
    K&N
    Boyesen reeds
    Magura hydraulic clutch
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Three Wheelin' Since '84
