Results 1 to 9 of 9
Thread: Cool Heads Do they work???
    a-camp's Avatar
    a-camp is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Orange Co.
    420
    Thinking of putting one on my list. Is it worth it ? Will it make my cyl. run c
    cooler? Or do they just look cool ?
    Mar 2004
    Eastvale, CA
    629
    Just my opinion but, they look cooler than they work. You'd have to use a temperature gauge to see how much, if any, they cool better than the stock head, and the difference would be minimal. Worth the cost, for the look, yes, too cool better to make a difference in engine life or performance, no, but you might see a gain (depending on dome size) if it increases the compression.
    Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
    Wife's Ride - 2009 Polaris RZR 800
    Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
    Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
    got sand?
    Anaheim
    1,270
    i say they make a difference, they look cool and wat a good freind of mine who owns a banshee with a cool head and has one of those temp. gauges in his fender that it runs like 5 degrees lower then be4 but i dont know iam buying a 85 R and thats the first thing iam doing
    adam
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    Nordern Minnesoata
    57
    Cool Head
    I have one on my Banshee. The only advantage performance-wise is the higher compression domes. The domes can be switched out, but I never do. I could have just shaved the stock head for higher compression and saved some money. Personally, I don't think it cools any more than stock. Then again, I have never had an overheating problem with stock heads or with the cool head. The cool head just might run cooler under higher compression, but again, I do not know for sure.
    The other advantage, is it looks fancy.
    So, if you are looking for performance, I recommend just shaving the stock head for higher compression. If it works- great. If it overheats because of higher compression, then try the coolhead.
    If you just need a cool looking piece of billet on your motor, get the cool head!
    Phil
    a-camp's Avatar
    Orange Co.
    420
    Sounds good . The only person I know with Cool Haeds has a Banshee as well. Does anyone have one on a 250r motor?
    A black one would not hurt the looks of my bike.lol
    May 2002
    Southeastern Wisconsin
    3,658
    I ran one on my TRX, I started out with a shaved head and should have stuck with it. As philmoore said I could have saved some money. The head mod is a must though. 2-strokes LOVE compression.
    a-camp's Avatar
    Orange Co.
    420
    Im at 198lbs or close last I checked I have a milled head that runs 205 but i dont use it .
    Mar 2003
    Kansas
    1,507
    I had one on my R, and the only thing cool about them are the looks and ability to change out domes to suit your riding needs for the day. I never noticed any changes in temperature with mine. All my riding was done on the sand dunes, between 70 and 100 degrees.
    Apr 2003
    394
    I never thought the 85/86 R's had a problem with temp. Our's runs fine stock. It's one reason we traded a 350x for it. Now those run Hot..........
    84'R pic page; http://magoos.wheatfarm.com/pictures/index.php
