Results 1 to 10 of 10
Thread: hotter plug
    svo58 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2004
    clifton park,saratoga county,N.Y.
    166
    hotter plug
    i am running a NGK dr8es,i was reading my spark plug and it looks to be running cold ,what would be a hotter plug to use.It's a 84 honda big red 200es,if i ride in 2nd gear it fouls the plug (dry carbon, not wet and oily) but if i go on a strightaway and get to 4th or 5th gear the plug is normal ,will a hotter plug help.........thanks,svo58
    84 big red 200es with speedo
    84 70cc ATC- new top end ,rear rack, head light and tail light
    85 250es big red
    85 250sx
    Apr 2002
    s.w. michigan
    6,498
    plug
    the next hotter plug is the ngk # 7. the lower the number the hotter the plug.
    dry carbon fouling is normally due to eletrical ( weak spark ) ,,, from what i have read anyway ,,,,
    john
    Howdy's Avatar
    Celina, Ohio
    10,079
    Anaheim
    1,270
    go to br7es cheapest in the series and also has a good metallic tip for better spark
    adam
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by RideRed250R
    adam
    I don't have my book in front of me, but from memory the br7es is a different sized plug ( Used in 2 strokes ). The D7EA is a direct fit and they only run $2 from me or $2.50 or so from Napa ( last time I checked ). No I'm not trying to sell any ( other than locally ). Shipping cost makes them more costly.
    Howdy
    Washingtons Crossing, Pa.
    2,977
    BR7ES is the "hotter" resistor type 2-Stroke plug. The thumper plugs should start with a D.
    Jun 2004
    Brazil, Indiana
    1,389
    so he should get a dr7es?..o by the way..my dads kawasaki kz 400 isnt a 2 stroker and it uses a br7es
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
    2,977
    Ok, well you got me with that one .... you had to find an ancient bike from the '70's to do it, but you got me ..... BTW - the KZ400/440 manual lists B7ES, not the resistor type if you want to split hairs as the proper plug.
    Glenn J's Avatar
    Glenn J is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2003
    Wallyword, CT
    155
    A slightly hotter plug would be the DR8ES-L. It's not as hot as a DR7ES, but a bit hotter than a regular DR8ES. The DR8ES-L is what the 83-85 200X runs. I believe the "L" is half a heat range higher than the 8.
    Best advice would be to go with what your manual recomends, then diagnose the problem from there.
    1985 200X
    May 2002
    Southeastern Wisconsin
    3,658
    This should answer all your NGK code questions:
    http://www.ngk.com/images/ngksparkplug.jpg
