Results 1 to 12 of 12
Thread: Why doesn't anyone know if a 2-stroke carb will run a 4-stroke bike?
    Studytime is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2004
    Louisiana
    203
    No one seemed to answer the previous threads that asked this.
    No one knows? How different could the fuel requirements really be? I don't see what the big difference would be.
    Please give some insight if you have any to offer.
    Studytime
    Quickonstep is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    Baltimore, MD
    368
    You are the engineer, you SHOULD beable to figure this one out.. but ill throw you a bone.
    a 2 stroke, has alot more velocity than a 4 stroke and is able to pull air in through a bigger diameter carb and venturi.. The 4 stroke doesnt have the velocity to do it.. altho with some work it MAY work, the work vs. benifits or lack of, wouldnt be worth it.
    Hope you are able to understand that.
    Jesse
    Nov 2004
    Louisiana
    203
    Quote Originally Posted by Quickonstep
    Jesse
    Didn't really understand all of that.
    As for a 2-stroke having more velocity that's not really relevant. There are two factors that determine how much air the motor will require- displacement and engine speed. The two-stroke would have the same instantaneous velocity as a 4-stroke, but would have twice as many intake strokes as a thumper and therefor would flow 2x as much- but at the same velocity. For each pressure drop they'd be close to the same action I guess.
    If both bikes are requiring around 12:1 AFR the fuel requirements are the same really. They both have to provide the proper mixture for idle, part throttle, and WOT. They should both be close I would think.
    Of course for a 250cc 4-stroke you wouldn't get a 250cc 2-stroke carb, you'd get approximately the diameter of the original 4-stroke carb.
    If anyone has any other information please contribute. I don't know everything and the 2-stroke stuff I said above may or may not be wrong. If it is feel free to admonish me.
    Studytime
    May 2002
    Southeastern Wisconsin
    3,658
    It's a carb, if you match the flow to the motor it will work. I'm highly supprised you don't know that.
    Nov 2004
    Louisiana
    203
    Oh, and I'm not sure that saying a 2-stroke has more velocity through the carburetor is an accurate statement. The 2-stroke carb has a larger diameter.
    Assuming a 200s and a cr85 both spun to 6200 RPM then the 200s would actually have more velocity at the carb (22 mm) than the cr85 (28 mm).
    For TWO crank revs you'd be fueling
    a) 200cc through a 22 mm hole
    b) 170cc through a 28 mm hole
    Of course we all know that when you increase the size of an orifice the flow through it will, of course, slow down.
    So, i'd say this 2-stroke has LESS velocity through the carb.
    Some a bone to chew on.
    Studytime
    Nov 2004
    Baltimore, MD
    368
    heres an idea, put a 2 stroke carb on a 4 stroke and then come back and tell everyone if it worked..
    Jesse
    KASEY's Avatar
    KASEY is online now weee weeee weeeeeeeeeee ! ! ! The day begins with 3WW
    ARIZONAS BIGGEST TROUBLEMAKER
    4,250
    ok i guess i will chime in on this one,,, the carbs are the same its the internal parts that are different,,,,, you can take a four stroke carb and convert it to run on a 2 stroke,,,, but as much trouble as i see on all the boards with jetting i would not recommend it ,,,, cause your going to have to go through every aspect of the fuel range,,,, the needle jet is the only part that is totally different, but needle ,slide cutout , and jets will have to be changed to get proper ratios,,,,,,,,,, the bodys are the same ,,,,,
    If you need to find information, do what I do. Use the internet and search, I've been searching for information on my Tri Z all day. Here I found this one for you on google, its good reading, scroll down http://www.ohv.8m.com/
    hope it helps.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Feb 2003
    Australia
    927
    Two stroke carbs do work on 4 strokes. I use 28mm CR80 carbs on my Project X ATC 70's because of their compact size. All I change is the needle. I replace the Keihin CR needle with a stock Banshee Mikuni needle. They couldn't run better. I have also used a 38mm Keihin PJ carb on my 550cc 350x with very good results also. The 350X had a modded FT500 head with huge valves as well. I still have this if anyone is interested.
    Most of the aftermarket carb kits which used to be available for the early 4 stroke ATC's were Mikuni 2 stroke carbs. The 28mm flat slide kits for 200X's were also 2 stroke carbs off a RGV500.
    Jul 2004
    minnesota
    689
    well i have experience with putting a old polaris snowmachine carb on my 200x, but before i put it on i cleaned her all out, it did start wiht it on but only ran for about 40 secnds,then after that i just decided to put th original back on, but maybee if i played with the settings alittle it pssibly would have ran longer.
    my trikes:
    1983 honda atc 200x-k&n filter
    2002 yamaha raptor 660r, yoshimura slip on, prm grab bars
    1978 chevy nova, 454 v8, bds blower, 150hp shot of nitrous, full roll cage, a real power house.
    1991 chevy s10 4x4 350v8.
    1986 250sx
    YES its fast NO you cant ride it.
    Nov 2004
    Waterloo IL
    2,701
    My cousin put a DT400 carb (2-stroke) on a TT500 (4-stroke) and it worked fine, he didn't even re-jet.
    Why does every one think a 2 stoke uses a bigger carb than a 4-stroke??? Weird.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    hey, put an 81 kawy 440 ltd carb on the 750x/cb750, with a 4 into 1 intake. had to jet, but works great. kinda sounds like a car, but flies.
    one cylinder is not enough!!
