Results 1 to 8 of 8
Thread: 200x does not like to shift into 1st gear, any ideals?
    been having this trouble for a little while, really makes hill climbs difficult,...
    my 85 200x does not shift well down into 1st gear. if I am in neutral I can
    get it in by tapping on the lever (sometimes rocking) and eventually it will engage, if I am riding
    in 2nd gear and go to downshift it wont go into 1st.(it leaves me in neutral
    at some very bad momets.. ie steep climbs)
    all other gears shift up and down fine & it will shift UP from 1st to 2nd fine,
    Has anyone out there dealt with something like this before??
    could be a bent shifting fork?
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    Jul 2004
    minnesota
    689
    i had the same problem with my 85 200x that i had, I dont rememeber whatthe part was called that was bad in the tranny but ill try to explain it as best as i can, ok when you take the right side tranny case off(the side with the kick start) you will se the oil filter and to the left of it there will be a start looking "gaget" covered up allittle bit by a peice of metal and if you look closely the ends of the points are most likely rounded off and that your problem at least in my case it was.
    my trikes:
    1983 honda atc 200x-k&n filter
    2002 yamaha raptor 660r, yoshimura slip on, prm grab bars
    1978 chevy nova, 454 v8, bds blower, 150hp shot of nitrous, full roll cage, a real power house.
    1991 chevy s10 4x4 350v8.
    1986 250sx
    YES its fast NO you cant ride it.
    Jun 2004
    Brazil, Indiana
    1,389
    is it sort of like a pinion gear for a carb maybe?..o yea and hotroddal..are u talking about that triangled piece with the bearings under it??if so i know what your talking about and on my 185 that thing would keep it from shifting into any gear
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
    Jul 2004
    minnesota
    689
    yes 83185s, it is sorta triangled shape.
    my trikes:
    1986 250sx
    HaggLE is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2005
    Newcastle, Australia
    330
    I have seen shifting problems with these motors before usually caused from riding without using the clutch or the gearshift cam is loose (star shaped thing). To fix, tighten the gearshift cam if its loose and try again but more than likely you will need the following parts:
    Gearshift plate (bottle opener like thing) P/N 24621-446-650 and a gearshift cam (start shape thing) P/N 24411-446-650. You may also want to get a "stopper" which is the little wheel on the little arm that runs on the gearshift cam P/N 24430-437-000.
    Jun 2004
    geraldton, west australia
    1,068
    oh cool, HagglE your from OZ...we get stronger by the day...and welcome
    LIVELOVERIDEDIE
    1981 Honda Atc 124R-Racer project
    2005 Giant STP 1- rollin' on 26's
    Jun 2003
    stockton nsw
    85
    whell heres another ozz...ish...you could have a weak detent...before we start tearing into things where is your lever set? are u gettin full down travel on the lever or is it hittin the fpptpeg?
    1982 Suzuki Sierra 1L - Nissan MQ axles and 38" TSL Swampers
    1982 LWB SIII Stage one Land Rover Tray Back- 4BD1 Isuzu powah!
