Results 1 to 11 of 11
Thread: need clutch help
    Nov 2004
    Lemoore, Ca
    44
    need clutch help
    when i put it in gear it stalls...even when i hold the clutch in. how do i adjust the clutch? when i pull the clutch lever it does not go into neutral.
    If its on, Lets get it over with!
    1985 KXT250 Tecate, Well sort of...84 frame, 85 engine, 86 front end
    Apr 2004
    International Falls Minnesota
    546
    Is your clutch cable adjusted right?? If your clutch cable is to loose it wont disengage the clutch.
    Nov 2004
    Lemoore, Ca
    44
    yeah its fine, even when i take it off and use vise grips to disengage it all the way it still wont go into neutral.
    Anaheim
    1,270
    have u checked trailprotrailpro transmission fluid? do u have enough, cause that does happen when u run the same oil to long (at least to me)
    adam
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    Nov 2004
    Lemoore, Ca
    44
    just changed it.
    a-camp's Avatar
    a-camp is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Orange Co.
    420
    Make sure cable is tight enough to pull lever on motor as much as possible . If this does not work you my need to operate. If you have never done this you may want to buy a shop guide on your bike.
    Nov 2004
    Lemoore, Ca
    44
    that sux. i hope i dont have to do that. im getting ready for pismo this weekend.
    a-camp's Avatar
    Orange Co.
    420
    Nov 2004
    Lemoore, Ca
    44
    i feel like a trailprotrailprotrailprotrailprotrailprotrailprotrailpro...did not realize that i put too much oil in the case. i had enough oil in there to fill 2 1/2 trikes. now it runs fine.
    a-camp's Avatar
    Orange Co.
    420
    Ill remember that.Chat rooms are great for this
    Nov 2004
    Lemoore, Ca
    44
    but anywho, thanx for all the help.
