Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Thread: lets see all the drag or FAST ATC250R's
    Mar 2004
    Eastvale, CA
    630
    Quote Originally Posted by BigGreenMachine
    What else did you remove or replace with lighter parts to achieve 277 pounds? Very nice looking R by the way.
    Thanks BGM. Basically everything that I replaced with the billet aluminum parts is where I saved the weight, plus the ITP wheels and lighter tires helped too. Losing the stock pipe and silencer shaved at least 10 lbs. right there.
    Removing the air box lid and running a better breathing filter such as the
    K & N will give you a slight power gain, but if you ride in mud and water it's best to leave it on.
    Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
    Wife's Ride - 2009 Polaris RZR 800
    Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
    Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
    got sand?
    Anaheim
    1,270
    hey? wat does a k/n filter in a 85 stock air-box look like?
    adam
    i just got mine and it sits sideways in the box and iam confused it doesnt look like a k/n it looks foamy?
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    Phoenix, AZ.
    6,719
    Here you go.
    Ontario, CANADA
    4,538
    does k+n make a filter for 84 R's?
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Mar 2004
    Eastvale, CA
    630
    Quote Originally Posted by Kintore
    I'm sure they did, but can you still get one is the question. It's possible the 85/86 filter might work if they have the same air box as the 83/84. Anyone know?
    got sand?
    Newfoundland
    5,280
    By any chance did you see the article on losing weight on a 250R. I belive they shave about 40 pounds which gave the bike a better power to weight ratio and also helps the suspension and handling characteristics. They used light wheels and alot of replacement aluminum parts as well as a +1 Cal-Fab (aluminum) and an aluminum sub-frame that was available.
    toyota200x's Avatar
    toyota200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2003
    402
    Quote Originally Posted by Dammit!
    Here you go.
    Is the filter in a 250r mounted sideways like that. On my SX it is not like that? Just wondering
    Thanks
    Owner of
    '98 klx 300r
    '85 250sx
    '82 185s
    Phoenix, AZ.
    6,719
    Well that IS a 1986 250R so... yes.
    Anaheim
    1,270
    so is my 85
    and a 84 is mounted straight off the back of the carb so no... but they do make a 84 R air-filter
    adam
