Results 1 to 15 of 19
Thread: Broke head off small bolt...any suggestions on getting the rest of it out??
    Jul 2004
    Baton Rouge, LA
    946
    Hey guys, well I accidentally broke off the head of the bolt which holds down my gas tank on my bigred. It's fairly small, 6X16 mm I think, with the body of the bolt still in the frame. I was thinking about drilling it out with a small drill bit. Any other suggestions/advice? -thanks appreciate it
    Aug 2004
    Ab Canada
    4,368
    you can use an Easy-out, or just drill it and re-tap the hole
    1985 Tri-Z-
    Jul 2004
    Baton Rouge, LA
    946
    How exacly does the Easy-out work? I've heard of it, just never used it before..
    Anaheim
    1,270
    well i have tried this if its not down in there TO FREAKIN HARD. all u need to do is drill down alittle apply pressure flip the sucker in reverse and see wat happens, also u can screw in a screw LOL with some super glue on it let it sit for a while and then back the screw and bolt out
    adam
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    Aug 2004
    Ab Canada
    4,368
    the easy out, you drill a small hole in the middle of the bolt, slighlty smaller than the dia of the easy out, tap the easy out in, and then turn it out...takes some patience sometimes to get it to catch properly
    1985 Tri-Z-
    Front royal, va
    2,186
    heat the area around where the bolt goes in, not the bolt itself, try a propane torch
    Quickonstep is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    Baltimore, MD
    368
    Quote Originally Posted by RideRed250R
    adam
    are you for real?
    bro, get yourself some ezouts, drill a small hole, tap it in, remove screw, done deal
    Jesse
    Mar 2004
    Newnan, GA / Near Atlanta
    1,727
    Pat, How did it break off. Over tightening it? Or Taking it out. If you over tightened it, it should come out pretty easy as long as it didnt bottom out on anything. Im thinking it didnt. Take a small punch or chisel, and tap on the outer edge of the bolt. Try to make the bolt turn with the force applied from the punch. Once you have a little groove in the top of the bolt on the outer edge, it should be pretty easy to get out. Dad showed me how to do this. Thanks dad! I used that method about 5 times on my 350X. I also used this method to get the drain plug bolt out of the differential. Works like a charm. Once it starts to move, it will back on out. Get you a little spot dished out and start working on it. If you dont have a punch or chisel, find a small screwdriver to do it with. Will prob be ruined when you get done. I use the drill and easy out as a last resort. I dont like retapping threads.
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    2008 Yamaha Rhino 700 SE
    Jun 2004
    Brazil, Indiana
    1,389
    yea..is the bolt a little out of the hole..i know u said u broke the head off but can u get it with vise grips? if not get the ez-outs
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
    This will not work in you application, but these suckers work stellar. They work on removeing studs and rounded nuts and bolts. 40 bucks at sears. If you use a easy out make sure you take your time and punch the hole dead center. Good luck.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    rustbucket is offline At The Back Of The Pack Arm chair racerFirst time rider
    pentwater michigan
    180
    if it is sticking out of the hole alittle bit 1/16-or more put a washer on it then a nut and weld the nut to the bolt grab a wrench and twist it out and if the nut comes of just grab it with the vise grips. also i have seen stud that stick out quite a bit heated up real hot then jam a candle on them and let it suck the wax in and they twist right out
    1980 trimoto 125 mods include a ripped seat broke fender and bent handle bars
    1981 trimoto 125
    1971 suzuki ts 185 it will spank a 200x
    1966 gmc 3/4 ton
    Bill X_R is offline Bill "The Finger" XR oo|oo Arm chair racerJust too addicted
    Feb 2003
    Cincinnati, OH
    672
    Quote Originally Posted by rustbucket
    LMFAO!!!!! A Candle....did you really say a candle!!!!!!
    That I gota see!!!!
    86' 250 R
    02' DS 650
    03' Cannibal
    03' Haspin Vet
    04' Haspin Vet
    05' Haspin Vet
    Minnesota
    47
    I think what he's trying to say is that the candle wax will get sucked into the threads and act like a lubricant!
    Aug 2004
    Ab Canada
    4,368
    oh yes weld the nut wile the gas-tank is on the bike real smart.
    1985 Tri-Z-
    Jun 2004
    Brazil, Indiana
    1,389
    if he broke the head off the bolt..the tank will lift off over the bolt....haha mts..lol
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
