Results 1 to 3 of 3
Thread: please help my 185s
    dc is offline First Time Rider Arm chair racerNew to the board
    Dec 2002
    117
    please help my 185s
    several weeks ago my 185s died on me and when I tried to start it again it backfired and my brother saw a blue flash from the tailpipe. I also heard a high pitched ping. I think I had got the electrical system wet the day before and that might have caused timing problems. It was just a day ago that I had time to asses the problem and deal with a carb float trouble. I got it running again but the exhaust sounded horrible. Something is surely broken inside of it. I will need a new exhaust and would like your input on where to get one. Also, what is the best way to dry the electrical system. Pull the case off and use a hair dryer?
    I miss riding my trike!
    Dec 2002
    117
    That's all right if you don't want to answer my question, guys. I'll post this at .org and get an answer from them. :evil:
    Howdy's Avatar
    Celina, Ohio
    10,079
    Sorry I missed this question.
    Using a blow dryer will work. Been there done that. lol Most likely though if it fired back up you won't need to worry about it.
    As for finding a replacement exhaust. That depends on what you want to go with. www.denniskirk.com has some exhaust ( or did ), and there are many other companies that have them also. If you want to keep it quiet go with a Cobra quiet series. I don't know what is still available for these machines but I would say there has to be 3-5 different ones to choose from.
    If you want OEM New try www.servicehonda.com if it's available they will be cheapest. How ever it still will be costly.
    Thanks
    Howdy
