Thread: Removing 200sx rear axle
    louisiana
    47
    Removing 250sx rear axle
    How do u remove the rear axle from the frame , The pivot tube in perticular
    thats located on the right side of the bike it has a crome cap over it, has a slotted nut on the outside and big allen head on the inside
    This big nut and bolt holds the entire rear it works in conjunction with the shock to move up and down
    Nov 2004
    Waterloo IL
    2,701
    You mean a 200SX 4-wheeler or what?
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    yea..what model are you talking about?
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    Howdy's Avatar
    Celina, Ohio
    10,079
    The 200sx ( 4 wheeler ) uses a bolt that goes through the swing arm and frame. Knowing this I will assume you mistyped and meant a 250sx 3 wheeler.
    To remove the swing arm you need to loosen up the lock nut ( slotted nut ) a little. Then use a big allen wrench and lossen up / remove the bolt / pin.
    Howdy
    louisiana
    47
    Yea my mistake 250sx Im working on 2 bikes at same time by the way got the 200s running. And thanks for the help thats what I wanted to know Undoo slotted locknut and back it out
    Aug 2004
    Ab, canada
    1,222
    Quote Originally Posted by Howdy
    Howdy
    Its awesome that we have guys that know how to do any of these machines that are willing to help out. Thanks.
    Rides:
    82 atc 200e
    83 atc 200e
    76 chevy k20 custom deluxe
    01 ford f250 diesel
    1938 Nash Lafayette
    1925 Nash Ajax
    My band:
    www.myspace.com/epicosgiliath
