Results 1 to 9 of 9
Thread: yam tri z 250 question: Will an 85 rear axle set up work...
    Hello,
    Will an 85 rear axle set up work on an 86 ?
    Thanks- Justin
    TRI Z Racer's Avatar
    TRI Z Racer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2002
    Boscawen, NH
    342
    im not exactly sure, but i think the only differences between the 86 and 85 are the transmision and the coolant overflow. I am convinced that the rear axle assembly should swap out
    1985 Yamaha Tri Z 260PV
    Suzuki Trail Buddy 50
    thanks for the response....I have an 86 with no axle, so I want to check around before I buy anything.
    200xer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    forks are larger on the 86 too. I would think that the axles are the same. Someone must know for sure.
    85 200x - Torn apart
    Rittman, Ohio
    6,276
    Same axle for 85/86 TriZ as well as the early model Banshees. Im not sure about the later Banshees.
    Aug 2002
    NY
    2,652
    an 85 and 86 axles are the same. and yes a banshee axle will work. i have a LSR +4 banshee axle on my 85 Z. plus i know that there were only a few differences between 85 and 86. like the others said the triple tree,forks frame and over flow bottle were different. not to mention the 85 5 speed to ther 86 6 speed. othewr then that all is the same. a banshee sprocket hub fits as well, and the sprockets them selves as well. hope this helps mike from long island
    Rittman, Ohio
    6,276
    Hey Mike, do the later Bnahsee axles work? Mines form a 88, but Banhsee change dthe carrier after that, and I wasnt sure if it was the same. Also, for more info, the rear brake disk and carrier for a Banshee will not work.
    Washingtons Crossing, Pa.
    2,977
    .... as far as I can tell, Yamaha only recently changed the Banshees axle and I believe its to a Raptor unit.
    Aug 2002
    NY
    2,652
    well i know the sprocket hub will fit. i have one on my 85 Z right now.plus i used the sprocket too. of course the carrier wont fit.as for the 88 axle i am unsure about that.i had an 89 and i know it was the same as my 2000. sorry good luck mike i have a 39 inch banshee axle from LSR not sure how much it is extended over the stock. well talk to ya later
