motor is from the 83 yz 250, and yes it rips alot better than modded tri-z engine!!i i removed it from the drag frame i had which needs paint real bad, in the spring it will return, and a stock, all stock motor will return to this bike
had to put a slightly less shaved head back on, my other one was too hard to kick, like my lt 500r, and kept blowing headgaskets, thats the only problem ive had with it, the carb is a big bell 40.5 mm, off of what, i have no idea, and a 4 by 4 inch uni clamp on to clear the fuel tank, the billet intake takes up alot of space, much easier to ride in the woods on the bottom end, yet pulls ALOT harder on top
Thats sick dude...that bike has some attitude. So its all bolt in?
Was it brain surgery putting a YZ top end on the Tri-Z bottom?
The Tri-Z I rode was surprisingly "trail friendly" for a 2 stroke.
I bet yours is SUPERB now!
GREAT Job!!![]()
That is a nice Z. The 40mm carb is probably off the YZ 250 the motor came from.
1986 Tecate
1984 Tecate
1985 Tri-Z
1986 ATC350X
1985 ATC250R (2)
1985 ATC125M (2)
1982 ATC70 - Original Owner
175 TriMoto Frame with Pro-Tec Rear Suspension
3-Wheelin' since '82
Looks nice!! I bet i can beat you on a ten speed bike.I recived the rim today too. Thanks again.
1985 YAMAHA TRI-Z 250 sold
2006 YFZ 450
I'm glad you posted that. I just bought a YZ engine for mine, and the guy I bought it from offered me another one as well. Now I have to find another Z to put it in!
I was wondering how to do the intake. Doesn't the stock Tri-Z intake fit?
Sweet job, looks awesome.
'85 350X-The Flagship
Speedo, Chrome HL Guard, Rubber Steps
DG Chrome Power, 6-Pack Rack, White Bros Skidplate, 400ex Carb
'85 250ES Big Red-Working in Style
Many Hondaline & Aftermarket Add-ons
'84 250R-Old School Racer Project
Too many Accessories to List
'82 200E Big Red-The Tractor
Rubber Steps, Tripmeter
'85 250SX-Rider
Various Accessories
'13 CBR250R & '05 CBR600F4i-Road Toys
Yoshi Slip-Ons & Fender Eliminators
Nice lookin trike man, I bet it tears up trails pretty good. Nothing quite like a 2-stroke Yami bike.
Rides:
82 atc 200e
83 atc 200e
76 chevy k20 custom deluxe
01 ford f250 diesel
1938 Nash Lafayette
1925 Nash Ajax
My band:
www.myspace.com/epicosgiliath
a stock tri-z intake wont work, and the yz inake kicks the carb INTO the pipe, it puts it way over to clear there airbox, mine was cnc machined at east coast atv, the reeds are big 8 petal design, all other year yz are 6 this motor was rebulit after being pulled from the cycle , it is a DIRECT bolt in, every hose etc...'but if you want lights for night rides you must use your flywheel and stator in the yz motor, but if you dont, the yz wiring WILL plug in and work in the z. even the pipe bolts up to the yz cylinder
i forgot, a yz kick backwards so you will need the kicker gears from a z which are not made anymore, and very hard to find
heres a pic of the intakes, and of the turbo, lightened crankshaft
Well, I just received my engine today. I see what you mean about the intake. Damn, that thing is turned bigtime to the side. I can build an intake easy enough, but i'm a little concerned that I don't have a reed cage. Does anyone offer an aftermarket reedcage for the YZ?
im not sure, im looking for aftermarket reeds for mine ( good ones) and can not find them
Wonder if there's anyway to cross-reference the part number on the intake gasket. See if it's the same up thru newer models.
I was looking for a reed cage and found this one for a 94. Looks like the same general bolt pattern intake. Maybe the newer YZ stuff will work. Just a thought.
Actually, the intake looks damn close to working too.
