Results 1 to 12 of 12
Thread: Flywheel weight reduction
    Jan 2005
    Miami,Fl
    73
    I cant remember wat its called right now but oh lighteing the flywheel how much difference does it makes and how much do i take off and how do i do it? Do i have to take it to a machine shop or can i do it myself? I have a 86 200s
    Aug 2004
    Phoenix
    1,226
    For a 200s it will not make any difference in performance to be worth the work.
    HaggLE is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2005
    Newcastle, Australia
    330
    A lighter flywheel will make your engine rev up faster. This is great for increasing speed along the flat. The negative is that you engine will rev down faster. So if your climbing a hill and start to loose revs then with a lighter flywheel you will loose the speed faster.
    If your flywheel is heavier it has the reverse affect.
    Front royal, va
    2,186
    you only want that mod for a two stroke... i remove 6-8 ozs. from every bike two stroke i have
    May 2002
    Southeastern Wisconsin
    3,658
    Quote Originally Posted by 03 ORANGE SHEE
    You want that mod for many 4-strokes. It's not just a 2-stroke thing.
    Mar 2003
    Kansas
    1,507
    Quote Originally Posted by OldSchoolin86
    You want to add weight to a 4 stroke... Lightening a 4 stroke flywheel would only benefit in drag racing, and everyone knows if you aint got a 2 stroke, dont bother drag racing.
    StangLX302's Avatar
    StangLX302 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    302
    Quote Originally Posted by CHAINSAW
    I'll race you with a 4 stroke.......car.
    Seriously though, I wouldn't try doing it to a 200s. You could also upset the balance of the engine if you did it wrong. Then it would vibrate itself to death.
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -Air filter box removed
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
    -200s front forks/shocks
    -Aftermarket 4 bolt rear wheels
    -Tire chains when ice riding
    1988 Ford Mustang LX 5.0L
    -Wayyyy too much to list!!!
    Front royal, va
    2,186
    all flywheels from the factory (oem) are stamped or cast , when you lighten them, it actually balances them better, even if to take off the outside mm, the bike will be MUCH smoother
    Fresno Ca
    2,695
    Hmm now i needa find me some extras so I can start plain around. My dad has a lathe (sp?) at work.
    Central CA
    459
    Lightening the flywheel on an engine with a centrifugal clutch? Seems like a lot of work for a small amount of benefit. Although what 'shee said is interesting. Sort of like brake discs on a car - if they are brand new you still have to turn them or else a HIGH percentage develop warps and general uneven service. The engine that I just took out of an '84 200S seemed to have vibration.... hmmmm... oh well too late I put it into a 200X chassis, we'll see...
    Rex
    Fresno Ca
    2,695
    Rex where in centeral cali are you? are you going to head to pismo with us?
    May 2002
    3,658
    It's a very popular mod on the 400ex's and not just for drag racing. Even woods guys are doing it! Also I'm sure there are some YFZ's and 450R's that would beg to differ on your drag racing theory. I know there are some crotch rocket motor swaps that would for sure.
