Results 1 to 15 of 16
Thread: Has anyone used BOTH the v-force and rad valve?
    Phoenix, AZ.
    6,719
    In the same bike? I'd like some real, informed feedback on these things. Planning to get one or the other.
    I asked the guy at Trinity about the v-force and the difference in power delivery versus the rad valve. His comment was the v-force hits a little lower in the powerband. About the same on the top end. He also said make sure to order it with the #7 material reeds (stronger). With the stronger reeds it runs about $148 so price is about the same I think.
    Mar 2004
    North Central Ohio!!
    2,712
    I'll add to that and say I talked to the guys at ESR and they said the exact same thing.
    Phoenix, AZ.
    6,719
    Well at least we know they probably aren't just making that up then. Thanks for the verification.
    Phoenix, AZ.
    6,719
    Gonna order the V-force tomorrow unless someone convinces me otherwise.
    Quickonstep is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    Baltimore, MD
    368
    buy the rad valve just because i said so SIR! hahahahahahahahahah
    WHAT ARE YOU DOING?!
    putting out a fire
    WHAT FIRE?
    its already out dumba$$ HAHAHAHAHAHAHAHAH
    Jesse
    3leggeddog's Avatar
    Nov 2004
    just picked up my v-force set up today and will be installing it this afternoon,i'll post up power differences as soon as i ride.our shop said that by far the v-force is a better set up,so we'll see.sure does look cool,can't wait no longer,i'm headin to the garage!!!!
    Aug 2002
    Creswell, OR
    889
    I am very anxious to hear a full report. I am going to similar setup. I would have sooner, but I keep getting distracted.....
    www.3wheeler.org
    * * * Nothing scares me more than someone who knows, with certainty, what is best for me * * *
    Phoenix, AZ.
    6,719
    Quote Originally Posted by threeleggeddog
    I'll hold off on ordering until we get your full report. Hurry!
    Mar 2003
    Kansas
    1,507
    I tried both in my Old 85 R, and didnt like either. Between the 2, I left the Rad Valves in longer (maybe a whole day) I used the V Force 2, so I cant say for the new V Force 3's. The V Force didnt stay in my machine barley a day. I ended up going back with plain old Boysen carbon fibers, because they worked best for my setup.
    Phoenix, AZ.
    6,719
    So how'd it go?
    3leggeddog's Avatar
    Nov 2004
    get this $h!#,got the v-force in no problems there.got the bike started up,and warmed up,pull in the clutch and the cable broke,ripped right off were it goes into the lever.looks like it will be tomorrow before i can go steal a cable off the parts bike,let you know then,sry
    atczack's Avatar
    atczack is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    Fort White, Fl.
    423
    I used to have a '87 TRX 250 fourtrax back in the day and I got the Rad Valve and there was a very noticable increase in the bottom end. I kept it in there ever time I changed reed's. I wish I still had that quad.
    1985 Honda ATC 250 Big Red
    "Ugly Betty" from the handlebars back it's a
    1982 Honda ATC200es, from the handlebars
    forward it's a 1988 Honda TRX 300 Fourtrax.
    "If you wanna play, you gotta pay..."
    3leggeddog's Avatar
    Nov 2004
    well i didn't get the clutch cable fixed yet,but still took the bike for a ride around my yard,the v-force seemed to make the throttle response more crisp,and snappy.i only ran it through 2 gears but i am convinced it made a diffrence.the bike come onto the pipe early and pulled hard till i shifted,almost ended up in the neighbors living room,BUY IT DUDE!!!!!
    Aug 2004
    Peoria, AZ
    625
    I put in a v-force II last year & it made the mid range come on more & a tad more throttle response. That over the stock with boysen 2 stage ones. I was told by a CR rider that you should move the adjustment on the v-force, losens the reeds, for optimal top end & I might try that later on. I'm happy with my bid sniped v-force IIs for $79!
    Newfoundland
    5,280
    Losening the reeds on the V-Force makes for more a lowend boost and wears out reed petals faster. I have a V-Force II in my T3, I'll compare it to stock when I get my jetting right.
