Results 1 to 10 of 10
Thread: Question about 350X Hubs
    Dec 2003
    SE PA
    683
    Question Question about 350X Hubs
    I'm working on a 350X project and I'm at the point where I need to find some rear hubs. I was curious if anyone out there knows if hubs from another bike will work, like 300EX or 400EX, maybe something that will get me a little more width. I tried to fit '85 250R hubs, but the 250R axle is a different diameter.
    Jun 2003
    South of Rochester, NY
    3,471
    350X Hubs have an extra spline or 2 compared to the 200X. Since everyone is saying 300EX etc huibs work on the 200X and 81-84 R's, I'd assume that they DON"T work on the 350X.
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Howdy's Avatar
    Celina, Ohio
    10,079
    I don't know of any other machines that the hubs fit on a 350x. So I think your limited to using 350x hubs.
    Howdy
    Dec 2003
    SE PA
    683
    Thanks guys. I wasn't real optimistic about it but I figured I'd see what kind of info I could get on the matter.
    I might have a extra set of 350x hubs for you.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Studytime is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2004
    Louisiana
    203
    I don't mean to steal this this thread, but you guys are saying that 200x hubs would work on a 200s? That way I could run 200x aluminum rims and 200x rubber.
    Studytime
    Quote Originally Posted by Studytime
    Studytime
    Yep they will bolt right on.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Dec 2003
    SE PA
    683
    I do need a good pair, clean with good studs and splines. If you have some you'd like to part with, email me at robmanero@comcast.net. Thanks!
    Jun 2003
    englishtown NJ
    2,676
    I gave a friend of mine 85/86 250r hubs and they worked on his 250x, with a 350x rear end.
    Rittman, Ohio
    6,276
    Im not sure about 85, but 86 and up TRX250R hubs fit 350X, as Im sure 86 ATC250R are the same.
