Thread: 83 185-S gearing.
    Jul 2004
    Pride, Louisiana
    286
    83 185-S gearing.
    I am wanting to lower the final gear ratio on my 3wheeler for better climbing. I was told that a smaller front sprocket is the way to go, but I figure that someone here has done this and will be able to help out.
    1977 ATC 90
    1983 ATC200E Big Red
    1985 Heald Super Bronc VT-10
    1999 Bayou 220
    2007 Polaris Outlaw 90
    Studytime is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2004
    Louisiana
    203
    That's correct get a one-tooth smaller front sprocket from denniskirk.com
    Many people here use a 1-tooth smaller sprocket at times, like for trail riding. Then you could always go to back to stock if you need more top end a different day.
    FWIW, your 185s has less aggressive gearing than the 200s. So, the ATC200s got better gearing and was more torquey.
    Studytime
    Washingtons Crossing, Pa.
    2,977
    You might have some better luck by replacing your 41 tooth a 47 tooth rear sprocket from the 200S.
    Jul 2004
    Pride, Louisiana
    286
    Coincidentally, I have a 86 200-S I just picked up for 100 bucks. I'll rob the sprokets off it and see what happens. Thanks.
    1977 ATC 90
    1999 Bayou 220
