Results 16 to 30 of 31
Thread: 480r cov. need help
    Apr 2003
    394
    I'm thinking the 480cc aircooled would be killer in a 83/84R. The power is awsome and they are reliable. Here's a link; http://www.off-road.com/dirtbike/hon/cr48083.html
    The write-up says there a five speed trans.
    Looks like alot of 480cc stuff is still avalible, like aftermarket clutches, reed's, gskt's ectt.
    I hear that the 480 kicker lever is a weak area.
    There would be a few things about converting one into a trike though. Theres no lighting coil in the stator for your headlight.
    Then you would need the wiring, cdi, coil, and electronics.
    Then the kick starter would be motorcycle style. So you would need to remove the rear fender assy. to start it.
    I've seen a few pic's and a article on the 480/trike. They all had something other than a factory fuel tank. I was thinking it was manditory for cleance, but was told by Mr atc that a factory tank will work.
    Motor mounts should be somewhat easy, but the factory air box would be tough to use. Then the expansion chamber/pipe is another story.
    Anyway it sound like a great project. Good luck and keep us updated.....................
    84'R pic page; http://magoos.wheatfarm.com/pictures/index.php
    May 2002
    Southeastern Wisconsin
    3,658
    Quote Originally Posted by My trike Sucks
    the water pumpers have left side chain drive, air's are left among other things there is one water pumper that i have seen in a air coold frame and it was a early cr250 with the right side chain drive....as for the swing-arm, if you can weld and use a grinder, you can extend a honda swing arm there like the easiest swinger to extend
    The right drive waterpumper was an 83 CR250 motor. I think if I was doing a convertion that's the direction I'd go. They both sound cool.
    Jan 2004
    Strongstown, Pa
    548
    so the 83cr 250 motor was right side drive? How hard do you think it would be to find a motor like that? what way do you guys think would be best to go? 83cr 250 or 83cr 480? what motor is easyer to find and still has a good amount of parts available?
    Thanks
    -Mike-
    Can't or Won't?
    Apr 2003
    394
    Quote Originally Posted by Atc_250
    Thanks
    -Mike-
    That's my delema also. Plus add a 300cc kit to the mix. I'll probily end up with a stock 250 air-cooled ..lol.
    Seems like a water-cooled cr250 would be more involved with the cooling system added to the other drawbacks desribed in the 480 reply.
    Good luck...........................
    Aug 2004
    Ab Canada
    4,368
    Quote Originally Posted by Troll 2
    heh thats like one of the main reasons im not fooling with the waterpumper in this frame, getting all the coolin stuff mounted and what not would be more work+ the fact if i wanted a 250r pumper i would just buy one to begin with, im going with the 480r becuse its simple air cool'd and theres no replacement for displacement!
    1985 Tri-Z-
    May 2002
    3,658
    Technology seems to be defeating that statement everyday. I bet an equally worked modern CR250 motor(2000+ year) would turn out similar hp. To be honest, I think that it would be sweet to be able to say you had a 480R.
    Aug 2004
    Ab Canada
    4,368
    yea i know OS86, lol but it sounds cooool hehe gona put a sticker on the grab bar"if you can read this you must be in a drag sheee" lol
    1985 Tri-Z-
    May 2002
    3,658
    I tell you what, if one of you guys make a 480R I want pics!!!
    Jan 2004
    Strongstown, Pa
    548
    it will be little while before i get to start on mine. im finishing up a 350x and let me tell you its turning out great. if i find my scaner i'll scan some pics for you. If any of you have a 480 motor and are goin to be selling it soon please let me know. Thanks
    -Mike-
    Can't or Won't?
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Aug 2004
    Ab Canada
    4,368
    heh blazerone i was gona buy that one but the peckers wont ship to canada GRRRRR
    1985 Tri-Z-
    I might be able to help you with that. Email the guy and see how far he is from Gladstone. I could put it in a rubbermaid container and ship her up there.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Jan 2004
    Strongstown, Pa
    548
    if only they would of waited to put that up in like a 3 or 4 weeks
    thats the bad thing about having another project not completed! thats a great deal to!
    -Mike-
    Can't or Won't?
    Aug 2004
    Ab Canada
    4,368
    ok blazerone ill do some digging and pm you later.
    1985 Tri-Z-
  15. #30
    Mar 2003
    Kansas
    1,507
    I picked up a 82 CR480 in the junkyard today. All the motor is there, and a little electrical. No carb, but the slide is still attatched to the cable. The reeds and intake boot is still there, along with a ratty old pipe. It looks like it used to be a sand dragger. It has like +12 swinger extensions on it, and a homemade huge chain guard and has an aluminum strut. Still has a 10 paddle, huge paddle tire on back. There is a lot of dust on it, and bird poo, so I thinks its been sitting in a barn.
    I think Ill try converting the bike into a trike. If its like the water pumpers, I can swap out parts from the trees, and have the 3 wheeler front tire. I probably wont mess with a rear fender, because plans are to paint it all flat black, and look like a beat up old air cooler.
    I havent tore into the motor yet to see if its locked up or anything. The kicker isnt catching at all either.
    So share some 480 info with CHAIN.. hehehe Im gonna slowly build this thing up as a sand draggin trike.
