I've tried everything. i'm sure my carb settings are all messed up but even so i thought that it would MAYBE fire up. i rebuilt this thing top to bottom, i'm just not sure which direction i installed the cam, lobes up or down? I pulled the CDI cas off and the stator case, i had the magneto on the T mark with the notch on the case, as well as the CDI thing lined up with the rubber piece with a notch in it. My only other idea is that maybe the cam was installed wrong? Any ideas?
~Last night when i discovered the hole in the gas tank i kicked it over anyway and it fired up for like a split second and that was it. :o
