hi all . i have a new atc speedo,cable and gearbox the only thing missing is the mounting bracket....can someone post a photo of the bracket and where it fits on the bike?????![]()
thanks
pete
thanks
pete
I can post you a pic of my 350X one when I get home. Not sure if the same, but sure it's similar to it.
Bruce
'86 ATC350X - 'Go-Go Girl'
'85 ATC70 - All Original
'83 Suzuki ALT125 - Pieces
Hi Bruce
i think the 350x is the same......the speedo is on the right side???(as you sit)
thanks for your time
pete
Ok.... here's a pic of the mounting bracket for the speedo ...here they be!
Bruce
and while I'm at it, I'll post up the mounting bracket for the Tachometer too. They mount in the same exact spot... excect on a pic in the Hondaline catalog! Anyhow.... they are entirely different beasts, so don't get them mixed up!
Bruce
Hi Bruce
your the man.........thank you very much for the photo's i can make one up now
pete![]()
I got more pics at home of a custom dash a guy offered to make me. However, I haven't heard from him in months... I ought to call him back up! But it was made of aluminum and designed to hold both the speedo and tach. I also bought a CB400 dash as an idea to mount them both too, but the guages have different spaced mounting posts.
Bruce
Do either of you guys (petesatc or 350x'inNY) have part #'s for the 250R speedo or mount kit?
Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
Wife's Ride - 2009 Polaris RZR 800
Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
got sand?
Nope.... no nothing about the 250R.
Bruce
sorry sandman i checked the box but it's so sun bleached i can't read the numbers...but here's a photo of the of the atc speedo......![]()
Sandman,
From what I can gather from the factory brochure I have, the part numbers should be as follows:
Speedometer (km/h) 08171-96510
Speedometer (mp/h) 08171-96500
Speedometer gearbox 08175-HA200
The pictures show the whole kit fitted under the description "Speedometer Gearbox", so I'm not sure whether that part number is for the gearbox only or the whole fitting kit. I think it's all discontinued now, but give it a go anyway. Need any other numbers, let me know.
Cheers,
Jez
Hmmmm.... I'll have to look at my boxes.... the 350X kit is HA5 instead of HA2 and has long been discontinued.
My speedometer itself has a different code.... I know it's not 965. 965 is 200X code I think. Seems like mine was like HC4 or something.
Anyhow... the kit is what I have pictured in my first picture post above. Everything that's on that white towel is in the kit (except the wiring (not sure where that came from) and also the top right corner is my original axle spacer and dust seal that you remove when you install the gearbox on the right front axle. Not sure if you could buy the gearbox by itself as a separate item.
Bruce
HA5 the product code for 350x and HA2 for the 250r the gearbox is the same .....on the right side(as you sit)
my speedo # looks more like a 9 than a H but i could be wrong...i think the 83 200x was the first atc to have a factory speedo and that's why it has 965.... 350x'inny speedo has'nt got the 'atc' decal on the face..... and hc4 is a trx 300 so it could be a later one
thanks![]()
True..... mine doesn't have the "ATC" on the face, but look at this pic from the Honda ATC350X brochure form 1985...
I think the early speedos circa like 83, 84 ish said ATC... but by 85-86, the handwriting was on the wall, and kits for Fourtrax's were coming out... and they ditched the ATC logo. Mine matches the Honda catalog, so I guess that's what the ones for my 350X looked like!
Bruce
350x, Does the tach mount in the same place as the speedo or can you mount it on the opposite side and run both set ups?
Jez, your part numbers are right on, thanks.
~Sandman~
got sand?
