Results 16 to 30 of 32
Thread: 85-86R speedo mount???
    wales..uk
    1,318
    Hi Bruce
    yep the 85 250r brochure has'nt got the 'atc' decal as well but check out the 86 200x brochure the 'atc' decal so who knows???? all we can say they both work and they are both are nos and oem
    wales..uk
    1,318
    sandman they can both be used together on the 350x and mounted on both sides speedo on right tacho on left....no tacho for the 250r unless you can find a odyssey/pilot tacho they work....... but they are rare as rocking horse sh**
    thanks
    Mar 2004
    Eastvale, CA
    629
    Quote Originally Posted by petesatc
    thanks
    Well, I'm real curious now. Does anyone have a part # for the Odyssey/Pilot tach? Jez?
    Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
    Wife's Ride - 2009 Polaris RZR 800
    Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
    Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
    got sand?
    wales..uk
    1,318
    sandman i can get you a part no. tomorrow for the tacho.....check the photo out it tops out at 10.000rpm instead of 9.000 on the 350x and is a 2stroke tacho ...i will post a picture of a real one tomorrow.... too late here and can't be assed to walk to the garage
    so i'm siging off till tomorrow
    thanks
    pete
    Jun 2003
    South of Rochester, NY
    3,470
    thanks
    Doesn't anyone read my posts???? I actually own this stuff... not speculating here!!
    Quote Originally Posted by 350X'inNY
    and while I'm at it, I'll post up the mounting bracket for the Tachometer too. They mount in the same exact spot... excect on a pic in the Hondaline catalog! Anyhow.... they are entirely different beasts, so don't get them mixed up!
    I found a pic in a Hondaline catelog with them both mounted together, but it also talked about a chronometer. It tracked the number of hours (time) you ran your trike. If you look in the back, this item was ONLY available for the 350X. (Can't find the scan of the last page, but will keep looking) This I have never seen or even heard of until last month when I saw it in the Hondaline Catalog for 86. I am assuming you got the 'dash with that that allowed you to mount the Tach with it.
    I'll say it again... the Speedo and Tach seperately have brackets that mount it in the same spot!! The factory mounts for the 350X Tachometer and Speedometer BOTH are designed for the Right Fork/Triple Tree. I stated that in one of my first posts on the thread. (see Quote ..)
    The 350X Speedo HAS to mount to the Right fork, cause the Gearbox HAS to mount to the Right side of the Wheel Hub for the tab.
    Now the "Banned and Nameless" rigged his mount for the Tachometer to mount on the Left, but it made the Tach sit lower than the speedo and he had to bend things around on it. I finally got this mount from him (he sent it out to someone as a speedo mount) this summer, and I can't remember where I put it in my shop. My 2nd Tach I bought had the mount with it, mounting instructions and even the original parts inventory slip from HONDA!
    Attached are pics of a custom dash a guy in PA made up and offered to give 2 of them to me. However, I can't seem to get a hold of him, and this was nearly 10 months ago.
    Also, I bought this CB400 dash, but after tearing it apart, the mount spacers are different.
    There was also a Tachometer offered from Hondaline for the 200X. Only ATC's the Tachometer was offered on was the 200X and 350X (at least in 85-86)
    Bruce
    Attached Thumbnails Attached Thumbnails CB400 Dash Pic Driver View.jpg   Custom 350X Dash.jpg   P3260152.jpg   DCP_1117.JPG   85-full-lineweb6.jpg
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Apr 2002
    s.w. michigan
    6,498
    a new meaning to rare
    thanks
    lmao ! rare as rocking horse - lol ! ( good one pete ! )
    now what 350xinNy is talking about is like the rarest of rare aftermarket parts ,,, complete tach + speedo AND chronometer combo. i hope i live long enough to see ( if not own ) that factory set up.
    john
    wales..uk
    1,318
    hey bruce your right the kit comes with the right hand mount but if you have a speedo already it will not fit so hondaline must have sold a different bracket for this ....... just check your own photo out or look below does 'nt it look like the tacho's on the left hand side????????
    hey sandman here the number for the oddy/pilot tachometer 08172-vm000 it works on most honda 2strokes....it's the same size as the speedo.......here a photo of mine
    thanks
    pete
    Jun 2003
    3,470
    pete
    Exactly what I said earlier ..... hehehehe
    and my last post...
    Quote Originally Posted by 350x'inNY
    I found a pic in a Hondaline catalog with them both mounted together, but it also talked about a chronometer. ... This I have never seen or even heard of until last month when I saw it in the Hondaline Catalog for 86. I am assuming you got the 'dash' with that that allowed you to mount the Tach with it.
    I have never seen a Hondaline mount for BOTH the speedo AND tach other than in the pic in the Hondaline catalog. I got that scan from erussell here on the board from his website. He's suppose to get the original out and tell me what it says under the pic. It's too fine and too blurry to read off his pic. Pete.... can you read/type the caption that's under the pic you posted?
    The mounts that come with the speedo and tach individually both mount to the right fork.
    As Swinehart put it... the speedos are somewhat rare.... tach's are even rarer, but the speedo/tach/chronometer combo may be the holy grail!
    Basically, the chronometer and ATC cover are the only Hondaline assessory I don't have for a 350X...
    Speedo - got it... Front AND Rear fender extenders - yep.... Front fender stabilizer - oh yeah.... Headlight guard - roger.... Rubber Footpegs - 10-4 Tachometer - Daily Double!
    Bruce
    wales..uk
    1,318
    hey bruce i've got that brochure check below.....have you ever seen that 5 function dial?????
    Jun 2003
    3,470
    Nope.... that's the "Holy Grail!" hahahaa Hmmmm... what's a "Unit Counter"??
    Interesting thing is that it's "Not Shown" ... I wonder if it ever made it out? If you look at the last page, it has a table of what assessories for which trikes.... that was only available for the 350X. I kept looking and looking for something in that pic, but I could never see it! So that tells me that HONDA must have at least made one speciall bracket to mount just the speedo and tach together for that pic. Like I said, I got 2 speedo mounts and 2 tachometers here, and they all mount to the right fork. The "banned and nameless" took the Tachometer mount and bent the tabs around so he could use it on the left, but it made it about 1" lower PLUS I think he said it made the Tachometer "twist" so it didn't display horizontally. I'll have to go dig it up! I made so many trips to his place this summer working on my 250R, new crate motor cam in my "Go-GO" 350X, and installing all new NOS parts in the Showgirl rear end amongst many other minor projects/tweaks. He's a great guy... never charged me a penny for the work nor the new cam... oh well... I'll have to dig through my parts boxes and find that Tach mount he gave me.
    That's the biggest difference in the tachs too.... the speedo mount post holes are parallel with the handlebars/triple tree while the tach is rotated about 40º.
    Bruce
    Jez is offline First Time Rider Arm chair racerNew to the board
    Channel Islands, UK
    105
    Bruce,
    To mount the tach on the left hand side, all you need is the bracket used to mount the speedo to any year ATC200X!!!! Find one of those and your problem is solved.
    Cheers,
    Jez
    Jun 2003
    3,470
    Quote Originally Posted by Jez
    Bruce,
    Cheers,
    Jez
    Jez... That will solve the height difference, but the mounting "posts" on the tachometer are rotated about 40º from those of the speedo. Basically, using a speedo mount will have the face of the tach rotated so its "sideways"
    Bruce
    Channel Islands, UK
    105
    More Part Numbers
    For those who asked, the part number for the ATC350X Tachometer is:
    08172-HA500
    It's been discontinued for a while now, but your local Honda dealer may be able to find one for you or may even have one left on the shelves. It's worth a try if nothing else. Need any other numbers, let me know.
    Cheers,
    Jez
    Jun 2003
    3,470
    I have found that the first 5 numbers describe the same part sometimes, then the next 3 are the model.... so I just typed the first 5 in at Service Honda and this is what I found...
    08172-GS950 TANK PAD 001 $25.61 yes $19.50
    08172-HA500 ATC350X TACHOMETER 001 $98.04 yes $74.51
    08172-HB500 ATC200X TACHOMETER 001 $60.28 $45.81
    08172-HE000 TACH WIRE HARNESS 001 $15.00 $15.18
    08172-MT200 S/B TRNK CRPT MAT KT 001 $47.95 $37.98
    08172-VM000 FL350R TACHOMETER 001 $46.00 yes $35.91
    08172-VM010 T/M ATTACHMENT KIT 001 $19.01 yes $12.49
    08172-VM020 FL350 TACHO INST KIT 001 $26.00 $19.95
    The "yes" means it's discontinued. The first price is Honda List... the second is the Service Honda price.
    I just got off the phone with Service Honda. I ordered the 200X Tachometer... will know tomorrow when they process my order whether it's truely "available" or not.
    Bruce
  15. #30
    RichinMO's Avatar
    RichinMO is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2002
    Waynesville, MO
    321
    Sooo....what's up with the 200X tachometer? Hate to dig up an old thread but this is interesting reading.
    1985 ATC250ES
    1985 ATC250SX
    1984 ATC200S "Little Red" - Trailer hitch, Hondaline: Front and Rear Racks, Cooler Rack, Tripmeter, HL Grille, Rubber Footpeg Covers, Mudflaps.
    1985 ATC70
    2008 CRF230L - Dual Sport
    2016 TRX500 Foreman Rubicon Deluxe
