Thread: carb size
    Nov 2004
    Lemoore, Ca
    44
    carb size
    does anyone know the stock carb size for the 85 tecate. not the keihin, the mikuni.
    If its on, Lets get it over with!
    1985 KXT250 Tecate, Well sort of...84 frame, 85 engine, 86 front end
    Las Vegas, NV.
    2,489
    According to 3Wheelerworlds own specs page, the '85 Tecate came with a Keihin VM32SS carburetor. So, according to that, the stock carb size is a 32mm.
    May 2002
    Texas
    2,670
    I'll look that up later. that may not be correct. The 84 was a 32mm. But I think they upped the carb to a 34mm in '85. And I believe they only ever had Mikuni Carbs except for the 88 Tecate-4.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    Nov 2004
    Lemoore, Ca
    44
    EDIT: Do Not Bypass the word filter!
    OldSchoolin86
    3WW Moderator
    Las Vegas, NV.
    2,489
    Quote Originally Posted by Jeb
    Jeb, I was thinking the same thing when I posted my answer. A Keihin carb on a 80's era Kawasaki just didn't sound right. Back then, Kawasakis traditionally ran Mikuni carburetors. Since I didn't have any of my old mags or brochures handy to refer to for the actual info, I thought I'd use the 3WW's spec page. The specs are correct on a few other bikes that I had looked at, so I assumed they'd be correct for the Tecate also. As for posting misinformation, I'm sorry to have been part of the problem & not the solution. I'll self-appoint myself to 1 week of super-secret-probation as punishment.
