Results 1 to 15 of 19
Thread: Quick carb Q. in or out for richer.
    Jul 2004
    Mud hill. close to water !
    3,658
    Ok... i read the entire manual, searched the forum, read a wack of threads. And i know i've read this before at some point... but i need to make sure of a tiny detail.
    ( not the idle, i know the idle is in for higher idle, and out for slower.. since it pushes the plunger up if you screw in, and lets it go down further if you counter-clock it. )
    The pilot screw however. the vertical one, that is accessible with a flathead screwdriver from outside the carb... air/fuel screw? Should it go IN or OUT for richer... ?
    I set it to spec... on an 82. 200, all the way in t'ill it seats, then 2 and 1/8 out. but it's running a bit lean ( white tip on plug .. after a 10 minute run off a brand new one, runing moderately hard. )
    anyone .. please.
    TheOlderFox's Avatar
    TheOlderFox is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2003
    Black Creek, WI
    299
    In is richer. There is a small hole in the carb body that the pilot screw fills allowing less air in
    Anyone know of a new project machine for me around Wisconsin?
    Jul 2004
    3,658
    Cool..
    Thank you very much !
    StangLX302's Avatar
    StangLX302 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    302
    That will only affect the air fuel ratio at idle though. You may need to up jet it. Do you have an aftermarket exhaust of air filter on it?
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -Air filter box removed
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
    -200s front forks/shocks
    -Aftermarket 4 bolt rear wheels
    -Tire chains when ice riding
    1988 Ford Mustang LX 5.0L
    -Wayyyy too much to list!!!
    Jul 2004
    3,658
    All stock. exhaust and filter.
    Might have to lower the clip a notch.. i have it on 2nd from top right now. Just put in a rebuild kit and used a vernier caliper to adjust the float exactly at 12.5mm so my float should be ok !
    HaggLE is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2005
    Newcastle, Australia
    330
    The smoothness of the idle is adjusted with the screw you are talking about. It also affects how well it comes off idle. To get this right, with the engine warmed up and idleing (about 1500rpm), turn the screw in till it starts to faulter, then turn it out till it starts to faulter. The midpoint between the two is right. When you are adjusting this screw, it takes a few seconds for a reaction so turn it slow. You may need to readjust idle speed after adjustment.
    The next thing to get right is the main jet. This is only on flat out revs. If it runs smooth up top when riding then its likely right. You cant go by judging whether the plug is white because only fuel with lead in it will give you a white plug with a lean mixture. Depending on the fuel but usually plugs go orange if its lean and black if rich. Find a straight and get a few gears up and hold the throttle flat out till its reving high and then hit the kill switch and grab the clutch. Check the plug and its should be marginally orange.
    The needle affects everything inbetween idle and full throttle. If when you give the throttle a quick push to flat out (not too fast just smooth and about 3/4 of a second from off to on) and it faulters then adjust the needle.
    All of this can only be done when the engine is fully warmed up.
    Jul 2004
    3,658
    Quote Originally Posted by HaggLE
    ^^^THAT'S what i was looking for. I do need to richen up the air/fuel a bit since i need to just " touch" the throttle with choke on when cold and it fires right up...
    But once warmed up that Quote is the 2nd problem, gonna try that later on.
    I find that the " turn the screw t'ill it falters.. then go the other way.. and find the middle is kinda tricky... a little bit of a turn seems to make a pretty big difference....... or i'm doing it wrong, i'll have to try again.
    THANK YOU VERY MUCH !
    Jun 2004
    Brazil, Indiana
    1,389
    ok so an 83' 185s...when i rev it full out and it sputters alittle bit is that getting too much gas or too little? it sounds like it wants to go higher but cant...but i got a new piston and rings for it so will that help any?? i think its runnin to lean cause it also overheated alot before i got the new piston and rings...although the spark plug is dry black
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
    Aug 2004
    Ab Canada
    4,368
    83'185s that sounds like a spark issue or too large of a main jet it normally is a 98-100 on the 185's...., as for the turning orange insted of white, maby your gas is diffrent across the pond but evey bike i have done if its lean its white and this is pump gas non ledded, just my 0.02 cents
    1985 Tri-Z-
    Jan 2005
    330
    ok sounds like we have different additives in our fuel compared to you guys.
    Sounds like its running rich to me. The best way to tell is trial and error. Go 5 points smaller in the main and see if it gets better or worse. Then you know whether you went the right way or not. should be around the size of 90-105. But as said before, 98-100 should be right. Slow jet should be a 38.
    When turning the mixture screw, it will make a big difference but make sure that the idle is set right before you do it and it will affect the idle speed when you are adjusting. Make sure that the engine is fully warmed up this is the most important thing whenever you are tuning an engine.
    Jul 2004
    3,658
    what would you compare 1500 rpm to.. not having an odometer.....
    Consider a properly running motor with idle as low as possible without stalling ( if i used my SX to compare , when i start it with choke on it revs quite a bit higher until i gradually remove the choke once warmed up.... and it goes to a nice slow putputput.... from vrrrrrrrrrrrr ) would 1500 rpm be much higher?
    Does that ^ make any sense?....
    Jan 2005
    330
    I just thought of something else
    Make sure that your ignition timing is set right. With the "F" mark visible in the hole your CDI spinner should line up with the line on the black pickup sensor with the spring thingo turned. This may affect the way it revs out.
    If you advance too far you will hear a noise in the motor when its under load that sounds like things rattleing in there. This is called Pinking. To reduce this you will have to retard the timing (turn it the direction of the motor) or run higher octane fuel or both.
    Good luck
    Jan 2005
    330
    1500 is low.
    a-camp's Avatar
    a-camp is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Orange Co.
    420
    Take a small screwdriver with you. Put screw to stock setting and clip on needle. warm up and ride. Go out a 1/4 turn and take a quick spin. Did it respond fastewr or slower. If you cant tell go another 1/4 turn . If you can feel a differance try another 1/8 turn out did it make a differance is it snappy.So from here you should know if you keep going out or back a 1/8 .If you cant tell go back to stock and go in a 1/4 and see if that helps.Dont go to far in from stock ( I think its only 1 1/4 on a R ).May need to drop clip on needle one. If you think you got it ride 10 min and give it a wide open plug check as discribed above. If you got it go another 1/2 hour and ceck it again. Where im from White is Hot Black is rich And COCO BROWN is good.
    Dec 2002
    salem, nh
    1,339
    wow these were all the questions i was going to ask. i'm working on getting my 200x to run correctly. all the carb settings are what i needed. now about the timing, i timed it up correctly with the F mark and also adjusted the valves, however I can hear a very loud clicking sound. Would it matter if the CDI "spinner" was off 180 degrees? because you can line up the F mark and the spinner mark will be facing down. Turn the crank one more time to the F mark and it will be facing up.
    85 250SX New to me!!
    85 ATC 70 stock ~ TRADED
    85 ATC 70 with 138cc Lifan
    83 110 restored ~ sold
    85 110 restored ~ sold
    83 200x restored ~ sold
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    Removed choke 42 pilot DJ146 main
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    IMS Roll front bumper
    Graydon Proline nerfs
