I just got my 200x running and I found that first of all it shakes like crazy, second of all it shakes so bad that the choke flips itself up. I never used a torque wrench during the rebuild, maybe there are too many loose bolts?![]()
85 250SX New to me!!
85 ATC 70 stock ~ TRADED
85 ATC 70 with 138cc Lifan
83 110 restored ~ sold
85 110 restored ~ sold
83 200x restored ~ sold
02 400ex ~~~SOLD
K&N filter
K&N jet kit
EHS Racing lid
Removed choke 42 pilot DJ146 main
HMF full exhaust
AC skids
Holeshot XCR rears
14t front sprocket
IMS Roll front bumper
Graydon Proline nerfs
I have never, never had that happen. Does it have a bent axle?
Something is wrong with it to shake that bad.
1985 YAMAHA TRI-Z 250 sold
2006 YFZ 450
this is all while tuning the motor and revving it up!
02 400ex ~~~SOLD
K&N filter
K&N jet kit
EHS Racing lid
HMF full exhaust
AC skids
Holeshot XCR rears
14t front sprocket
then you need to take that motor apart, and rebuild it because SOMTHING is waaaaaaay off.. a bent rod wont vibrate that much but a bent crank defaintly will... take the crank out and send it to a machien shop to see if its straight
Jesse
Originally Posted by twgranger
Maybe it's nervous! Does it idle very fast?
Sounds like the chicks might like it . lol Is flywheel on OK ?
you did torqe down the nut to hold the clutch basket on RIGHT? and the flywheel RIGHT? and your crank was true RIGHT?
1985 Tri-Z-
Originally Posted by mywifeknowseverything
Yeah my 200x did that to me one day ,I was riding by myself in the midle of nowhere the engine stoped I checked everything ,spark ,fuel yada yada yada .Finally I found the problem and she started.A couple of months later I was riding and the crank shaft broke on the flywheel side and it made a real mess.
is there any noise in the motor ( clunks , banging , tapping ect. ) ???
john
valve tapping very loud, and i already adjusted them
02 400ex ~~~SOLD
K&N filter
K&N jet kit
EHS Racing lid
HMF full exhaust
AC skids
Holeshot XCR rears
14t front sprocket
I would'nt start that puppy until you iron out the kinks.....
that don't sound good at all.
For your sake, I hope it's a loose motor mount.
But if your valves are knocking that bad, I'd listen too bigredhead as if they were my grandmother with her lickin' stick in hand.
If you can't fix it with a, its an electrical problem.
85 ATC 200s--Ratted out and not running at the moment
86 ATC 200x--All stock other than the handle bars
85 ATC 250es Big Red -- Just got new rubbers and she wants to ride!!
04 Suzuki LTZ250 quadsport - It was a decent price and I'm a raging idiot.
i think it's ok, it was just revving too high. still ironing out the kinks. took it for it's first blast down the street only in second gear to see how it ran. Ran great, however it has an air leak between the cylinder and the head. You can hear it crack sometimes and I can feel the air being forced out. I'll have to check the gasket this weekend.
02 400ex ~~~SOLD
K&N filter
K&N jet kit
EHS Racing lid
HMF full exhaust
AC skids
Holeshot XCR rears
14t front sprocket
If you're choke is turning on by itself then it sounds like your fetzer valve is sticking and is full of gunk.![]()
Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
Wife's Ride - 2009 Polaris RZR 800
Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
got sand?
