Results 1 to 10 of 10
Thread: 200e oil on plug
    Jan 2005
    brampton, canada
    7
    200e oil on plug
    Hey! fellows I just bought a 1983 200E, When I bought it It didn't run so I cleaned the carb, I put a new float set, because the plug was wet with gas and I could smell the gas in the oil. After I changed the oil and put a new plug. First crank it fired up but dosen't idle and there is oil on my spark plug. I was wondering if somebody had any sugestions for me, I would really appreciate the help Thanks....
    Jul 2004
    Mud hill. close to water !
    3,658
    If you have the tools do a compression test, this will tell you a few things.. top end or worn rings...
    rich running and unburnt gas would also give you that impression, black liquid on plug.
    Nov 2004
    Waterloo IL
    2,701
    Not a help to this thread but when I first read the title I thought it said 200E coil on plug. I was like whoa, I gotta see this. lol.
    If it has oil on the plug I take it that it smokes a lot? Rings would be my guess, I've barely seen a 200 that didn't need them.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    HaggLE is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2005
    Newcastle, Australia
    330
    We need to know whether its smokey or not. If it is, keep it running for a while and if the smoke clears then id say its valve stem seals. If it doesnt then its the rings. Is it really easy to pull over? thats also another indication of worn rings/low compression.
    Jul 2004
    3,658
    how expensive and difficult to install are valve seals?
    My big red is in need ,,
    Nov 2004
    Waterloo IL
    2,701
    Valve stem seals are cheap and fairly easy to install. I really can't see them being bad enough to oil foul your plug though.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
    Jan 2005
    brampton, canada
    7
    It was very smokey before I dumped out the old gas. With the new gas it starts right away and dosen't smoke but still dosen't idle even with carb adjusted to factory specs. With my thumb on the plug hole there is lots of compression when I crank it over. I also took the valve covers off and they are covered in oil, I don't know if thats normal.
    Aug 2004
    Ab Canada
    4,368
    to get it to idle nice turn the screw on the left side of the carb IN for higher idle, you set this when its warmed up, and the air screw(the one thats upsidedown bottem of carb) you set as follows, when warmed up and idleing set to factory spec, then turn the screw in, in half turns untill the motor starts to faulter(runs crappy popping noise wants to die ecte ect) then count the half turns OUT untill the motor starts to faulter again, then put it in the middle of the 2 faulter points, the needle clip on the slide should be in the middle notch, also what size of pilot and main jet are you running ? should be a 38 pilot(small one) and a 95-100 Main jet(big one) normally. once you have the idle and air screw set right you can start messing with jetting via plug chops
    1985 Tri-Z-
    Aug 2004
    Ab, canada
    1,222
    Put in new rings, and valves since they are cheap, new gaskets well your at it and it should do fine, I've got two 200e trikes. There hardly be a used big red out there that doesn't need new rings. I'm completely redoing my 82, and the 83 is almost so bad that we make whoevers riding it go at the back of the party every ride. Luckily parts are pretty cheap.
    Rides:
    82 atc 200e
    83 atc 200e
    76 chevy k20 custom deluxe
    01 ford f250 diesel
    1938 Nash Lafayette
    1925 Nash Ajax
    My band:
    www.myspace.com/epicosgiliath
    Jan 2005
    brampton, canada
    7
    Thanks to everyone who responded I appreciate the advice, I will change the rings and valves and let you know the outcome.
