Well, I WAS going to put my NOS tank scoops on for the photo shoot but I dont have any of the little screwsI found some but they weren't long enough, oh well. In a few of the pictures is also my 200x and that aircooled 250R I bought a little bit ago.
The one picture that is a close up of the frame area, with some of the paint missing is where I am hiding all of my electrical stuffThat cover with part of the coil sticking out is actually the air dam that catches air and runs it into the airbox on a stock 350X. I couldn't find anywheres to mount the XR500 CDI since it is odball size and shape, so it got mounted actually inside the frame, and the coil mounts on the backside of that cover, and the cover bolts back onto the frame with some small tabs I made. Pretty nifty if I might say so myself.
You'll also notice that even though the frame was lengthed 3 inches, the 500 is not that much taller then the 84 R, even though it has larger tires. I've been just about driving myself nuts to try and keep everything as low as possible (For handing purposes). The forks are not slid up in the clamps any either, when I go to 20's (The trail pros are for rolling around the shop only) and raise the forks, It will be at a very manageable height and I dont think it will be anymore tippy then a normal 350x.
Kicker and brake pedal need a little bit of warming and bending to get into proper posistion. Kicker hits on the bottom bolt that holds the mastercylinder against the frame right now. If I keep cranking it over and running it the head will be worn off and I wont have to worry about it![]()
http://www.files.3wheelerworld.com/r...res/500X/1.jpg
http://www.files.3wheelerworld.com/r...res/500X/2.jpg
http://www.files.3wheelerworld.com/r...res/500X/3.jpg
http://www.files.3wheelerworld.com/r...res/500X/4.jpg
http://www.files.3wheelerworld.com/r...res/500X/5.jpg
http://www.files.3wheelerworld.com/r...res/500X/6.jpg
http://www.files.3wheelerworld.com/r...res/500X/7.jpg
http://www.files.3wheelerworld.com/r...res/500X/8.jpg
http://www.files.3wheelerworld.com/r...res/500X/9.jpg
Comments and criticism appreciated![]()
