First, id like to say hello to everyone as this is my first time posting on these boards. I recently regained intrest in the old 85 200s atc thats been sitting in my garage for longer than ive been alive. I am currently trying to fix it up, although it runs good and strong, just needs a little tlc and maintence to get it back in shape.
A few years ago, i tighetend the nuts which hold the exhaust header onto the engine. Being young and stupid, i decided to crank them as tight as possible, making one of them snap off. The bolt which comes out of the engine block is now about half the size and is of no use. I swore a few times and just let it be with a little noiser trike than before.
A few days ago, i looked at the bike and was like, im going to go buy a new front tire and get it running again. I figured out how to get the tire off, went to the local tire shop, and had a new one slapped on the rim for 65 bucks. Note that 2 of the same tires cost 70 total 8 years ago when my dad replaced the rear tires. When finally reinstalled the tire, i did the same thing as i did to the exhaust header mount. I over tightened ione of the nuts and snapped the bolt again. Its one of the 4 bolts which hold the axle onto the fork on the non brake side of the rim. Im sure you all get what i mean, and if you dont, i can get some pictures.
Now, where i need help. Are the bolts im talking about pressed into the engine/fork or are they screwed in? What would be the proper procedure in fixing this problem? Should i leave it be? I have a friend who owns a little machine shop, and im sure he could drill out the bolts, and retap the holes so i could thread another bolt in there and attach it like before. Please let me know what you all would do.
On another note, i ordered new brake pads/shoes off of ebay, and im about to order 2 new brake levers because the ones i had snapped a while ago, and ive just been using the foot brake. DO you think a slightly bent rear axle is worth replacing? How hard are the brakes to work on? I ordered the repair and service manual on a cd off of ebay, and i cant wait to check it out when it finally comes in.
One more question...I need a new air filter...I found a K&N one for 40 bucks free shipping to my door...is that a good deal? Should i just find a cheaper one?
Thanks,
Mike
