I have a 1985 200s and 200x and when I tried replacing the head and tailight on both of them, the lights came on when I started the trikes and blew out as soon as I revved them up??? Any help would be appreciated
The simple reason for this is the stator / generator is producing too much power for the bulbs. I have seen this quite a few times. This could be caused by many different reasons: bad wiring harness, bad ground wire, bad CDI box, and others. What I do to fix this style problem is to install a aftermarket volt pack. The volt pack is basically a 12volt regulator that limits the voltage to 12 volts. These are not that expensive and pretty easy to install ( 2 wires ). If you need 1 or 2 let me know. I think I have some instock.
Howdy
I can not and will not argue with Howdy,( he is the man,and he is probably correct). I will however suggest that you check your ground carefully. I blew quite a few bulbs before I checked my ground , and since I cleaned off the rust and grime where the ground is connected ,I have not had a problem. Good luck, GREG
1985 ATC 250R
2006 TRX450ER
RIDE RED...IS THERE ANYTHING ELSE??????????
howdy ill take one of them. were do i connect it (splice in to any wire on the trike?)
1985 atc 110 for sale
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
uni clamp on air filter
350x front end
I agree.In other aplications this is called a rectifier.Some after market light co. send you inline ones to solve the problem of their lights not being able to handle fluxuations in power.
You can use the stock 350X regulator on a 200x and it will fix the problem. Only one wire to connect.
ATCnut
82 185s - sold
83 200x (hopped up)
84 200x (stock)
84 70 (lost this one to the DMV)
85 70 (soon to have lights, a foot brake, and CDI ignition)
84 200es (parts trike) - sold
85 350X (the best)
85 350X (siezed motor, dream of a poweroll kit someday)
85 250sx (frame was trash, got parted out)
86 250sx (the tractor)
86 250sx (a nicer tractor)
86 250sx (an even nicer tractor)
87 200x (parts trike, its really rough, a dog was chewing on it for a while)
87 250es Big Red (the tank!!)
The rectifier converts AC to DC. Some do have the voltage regulater built into them though. Others are separate units. Howdy is right. Its a clipper circuit that shorts anything above 12v to ground. Its easy to check with a volt meter. Start it, connect to any hot wire. If voltage jumps when you rev to about 40v, the regulater is not working.Originally Posted by a-camp
[QUOTE=TimSr]The rectifier converts AC to DC. Some do have the voltage regulater built into them though. Others are separate units.
Thanks I did not know that . Have no resone to doubt you.
howdy how much are they?? and will they work on a 185?
trikes owned:
85' 200m - sold
84' 200x - sold
83' 185s - sold
82' 185s - sold
85' 350x !!! - selling
I haven't gotten a chance to get to the shop and check on them yet.Originally Posted by 83185s
Work on a 185? yes they do! These work on any 12 volt system.
Howdy
cool thanks! i may buy one just to make sure my lights dont burn out
trikes owned:
85' 200m - sold
84' 200x - sold
83' 185s - sold
82' 185s - sold
