Results 1 to 8 of 8
Thread: whats the best way to split cases on motor?
    Jan 2005
    I was wondering what tools I would need and the best way to split the cases on a motor (tri-z).I have it down to the cases but i dont know what to use to hold the clutch.I know they make a clutch holding tool and was wondering how effective it is? thanks in advance for your input
    ____________________________________________
    85 tri-z being restored and modified
    85 triz I just bought for 20 dollars less a motor
    89 blaster modified
    93 blaster torn apart
    85 honda 200x
    2002 katana
    1982 katana 1st year
    Aug 2004
    Ab Canada
    4,368
    just put a ratchet extension through the connecting rod while it is at bottem dead center, so when you go to take the clutch nut off the crank is staying still....get what i mean>?
    1985 Tri-Z-
    May 2002
    Southeastern Wisconsin
    3,658
    Welcome to the boards, when you have a trike question you should post it in trikesylvaina. I've moved this one for you. You should find the help you need here.
    '02 Honda 416ex - A seasoned blend of 11 herbs and spices
    '04 Honda Recon - The yard machine and snow plow
    '88 Honda CR250R - Another chapter in my torrid all terrain affair
    May 2002
    Texas
    2,670
    I have a vise-grip type clutch holder tool that works great. It will also hold flywheels and gears.
    To split the cases, you need a case splitter tool. It's basically a bar that bolts to the flywheel cover holes in the case and has a bigger center screw that will push on the crank and push the cases apart.
    If I'm understanding you, I don't think that putting something through the small end of the rod would hold a back up on the clutch nut. With the clutch disassembled (springs, pressure plate and fiber/metal plates removed) the center part of the clutch is no longer connected to the crank and if the engine is out of the frame or in the frame with the chain off then the tranny and center part of the clutch will just free spin, even though the crank is backed up by the extension through the rod.
    But that will work for taking the nut off the drive gear that bolts directly to the crank.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    3-Wheelin' since '82
    Jan 2005
    Quote Originally Posted by Jeb
    thanks Jeb you understood exactly what my problem was,i guess i will buy one of them tools. thanks again!
    Washingtons Crossing, Pa.
    2,977
    ... a really sharp flat head screwdriver and a 10lb sledge .......... JK.
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    I go about it the rdneck way and gently use a flathead screwdriver and a very small light weight and tap around it. Has always worked for me.
    Aug 2004
    Ab, canada
    1,222
    I tap on them GENTLY with a deadblow mallet to initially free them, then use a screw driver being careful not to scrape the inside of the case.
    Rides:
    82 atc 200e
    83 atc 200e
    76 chevy k20 custom deluxe
    01 ford f250 diesel
    1938 Nash Lafayette
    1925 Nash Ajax
    My band:
    www.myspace.com/epicosgiliath
